Question about Home
Triton amber 3 no water coming out, flow in good and electric ok but still nothing had fitted they say it must be faulty can u help and the filter is clean
  • 44 Answers
SOURCE: triton opal electric shower overflow pipe
hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
Kindly
Richie
Posted on Dec 15, 2008
  • 34 Answers
SOURCE: triton t80i water only warm in winter
That sounds like a water heater problem, wheres the heater at in your home. If it is effected by the outside weather i.e. the heater is in a cold environment then it would effect the hot water output. try turning up the thermostat on the heater if it is gas then it should be knob on the outside if it is electric you will need to remove the top or the bottom cover and adjust it with a screw driver. If this does not work the let me know and we try some other things. With the weather/temp outside effecting the water temp in the shower then I have a hard time believing it is the shower its self.
Posted on Feb 06, 2009
  • 5 Answers
SOURCE: the unit will not heat any water, press hot but goes straight to
probley heater eliment ? if not megga dear unit buy new one probly cheaper as long as u fit ure self
Posted on May 18, 2009
  • 3 Answers
SOURCE: My triton martinique electric shower low pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Posted on Jun 30, 2009
shadowarrior
  • 43 Answers
SOURCE: My triton martinique electric shower low pressure light comes on
how on earth is this related to gaming consoles or PS3 ??
Please post under correct sections next time.
Anyways, it looks like a common problem for the Triton Shower, and it might cost you some $90 to fix it.
http://www.comparestoreprices.co.uk/showers/triton-martinique-10-5kw.asp
Posted on Sep 07, 2009
I have a triton Amber 3 shower and last niht the water just stopped coming out mid shower. I turned it off and back on again no water at all .. thenit came back ok for a bit then went off again.. jus
Sounds like it is clogged. Buy a bottle of CLR, put some in a bowl that the shower head will fit in, remove the shower head from the pipe and let it sit in the bowl of CLR for a few minutes. If you run a search, there are regular household items that you can buy instead of the CLR. Might be cheaper.
Nov 20, 2014 | Home
Triton cara shower has power and water to it but nothing comes out
CHECK YOUR POWER SUPPLY BOX MAKE CERTAIN THAT IT IS INDEED ON IF SO IT MAY BE A BAD CIRCUIT BRAKER MAY NEED TO REPLACE IT.
Apr 15, 2014 | Camp Chef Triton Hot Water Shower Heater
Theres only a low flow of water coming out of the shower.
remove the head and make sure you have a good flow to the head if you do look to see if a plug needed to be removed before installation if their isn't return the product
Jul 06, 2012 | Home
I have a triton Amber 3 shower. No water flows when switched on - but the mains LED is lit and water is available
the solenoid has failed,thus not opening up to allow water flow,i have found that spares are fairly expensive for tritan. if you find out the rating ie 7.5 kw etc then buy a replacement shower from wickes their showers are tritan and are normally like for like fitting,also a lot cheaper than showers that have tritan marked on them.
Sep 05, 2011 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Nov 11, 2009 | Water Pik Waterpik& Elements& Fixed Mount...
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
No Water flow thru Humidifier
Loosen the brass fitting where it connects to the soleniod valve. If water comes out your saddle valve is ok. Carefully retighten this fitting. With the humidifier turned on loosen the first fitting down stream from the valve see if water comes out. if it does turn the humidifier off and see if it stops, it should. That will tell you the the valve is ok then, just clean the filter and the oriface. if it does not turn on and off check the wiring. if ok replace the valve.
Good luck
Nov 22, 2008 | Honeywell HE365 Humidifier
Home Logo
147 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
