Question about Pinnacle Computers & Internet
Hello sir i have a pinnacle pctv tvcenter analog 4.21. i have some problem during installation the software. after the few steps of installation i have found some error - Feature Transfer Error Feature : Microsoft. Net Framework version 1.1 Components : Microsoft dot Net Framework 1.1 File : F:\setup\..\Microsoft.Net Framework 1.1\dotnetfx.exe Error : Data error (cyclic redundancy check) that message shown on the screen. i don't know about that plz help me and tell me some solution for that problem.
antiochpc
  • 1314 Answers
SOURCE: trying to install the sims
Either the disk is damaged or the optical drive is going bad.
Posted on Jul 06, 2008
LASITHA-VEGA
  • 428 Answers
SOURCE: error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
Posted on May 28, 2010
grantg1983
  • 218 Answers
SOURCE: Gear Head WC875FT webcam software install problem.
i think thats a compatability issue try a new web cam 3 dollers from ebay hope this helps
Posted on Jul 12, 2010
studangerous
  • 98 Answers
SOURCE: Have old Trains & trucks
It's a CD error. Try cleaning the CD with some alcohol and the drive with a laser head cleaning cd. If it still fails to work you could try copying the files on the disc to a folder on your PC or burning it to an iso file and mounting it iwth Daemon Tools. That may help overcome the install error but it's not a certainty.
Posted on Sep 03, 2010
  • 10406 Answers
SOURCE: HI GOOD EVENING I AM
A "CRC" (Cyclic Redundancy Check) is caused by an disk-drive error.
When you write a "block' of data to your disk-drive, a CRC value is calculated, and is also written to the disk. When you try to read that "block" of data, the CRC value is also read from the disk,
and a new CRC is calculated from the data. If the "new" CRC does not match the "old" CRC, then you have a "check" condition -- either the data was not written correctly, or the data could not be read correctly.
Now, did the "check" message refer to the "source" of the copying operation (namely your 'C:' drive) , or the "target"(namely the external drive) ???
Try to copy the PST file to another file on your 'C:' drive.
If you do not see the "check", then it is the external disk-drive that has a problem.
If you do see the "check", then open Outlook, create a new folder,
and copy a group of messages into the new folder. If Outlook reports that one of the messages could not be copied, then the disk-space occupied by that message is faulty, and must be excluded.
Posted on Sep 07, 2010
Pinnacle pctv 100i software download with key
Download And Install it...........
http://cdn.pinnaclesys.com/SupportFiles/TVCenter/PinnacleTVCenterPro4.9.1.exe
u need a this key after downloading
JCHER-NBBAA-BGAAB-AAANB-RUWUC
Feb 24, 2009 | Foxconn 661FX7MI-RS (661FX7MIS)...
Pinnacle PCTV pro stick 801e
Hi Adam,
Here is the link for tv center pro for your vista 64 bit download and install this to your computer. http://cdnexpress.pinnaclesys.com/akdlm/SupportFiles/TVCenter/TVC540/PinnacleTVCenterProSetup_5.4.0.3032.exe.
I suggest also to connect your tuner device at any usb port.
By the way you need the serial number for the new tv center pro.
Enjoy.
Dec 11, 2008 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
PINNACLE PRO
Probably you need to do this in two stages.
1. Save the movie to your HDD -
www.vdownloader.es is good free software for saving clips, for example, from youtube etc.
2. You need a video card with a TV output to transfer the clip to your TV screen. Maybe your Pinnacle card can do this?
Hope I understood your question correctly.
Cheers
Apr 03, 2008 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
I have a Pinnacle PCTV TVCenter PRO version 4.7
celo disco pinnakle PCTV TVCenter PRO version 4.7 problema perso codice di instalazione
How to get compatible to vista version OS
search in pinnacle website ... u will get vista supported installations
Nov 28, 2007 | Pinnacle PCTV 110i (210100458) Video...
Computers & Internet Logo
153 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
