Question about Toshiba Portege R100 Tablet PC
Portege R100 (Toshiba). I have not used this laptop in over a year and can not rem the bios password I'd set. Tried all I could think of. Is there any way to reset the password on this?
    Sergeant:
    Champion:
  • 215 Answers
Hi,yes there is but you'll have to open the system up,if you have no prior I.T expertise I'd suggest you take to a qualified Technician,but if you do here is how:First remove the Battery,then uncouple the system taking of where each of the screws go to then locate the CMOS battery(small battery Lithium Ion mostly in the shape of a cent or smaller),it may be underneath the keyboard or just behind once the external cover is open.unplug it from the system for about an hour or two reconnect it,couple the system and boot,go to Bios,reset Date and Time and save,then exit.
Posted on Dec 31, 2010
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 13, 2012 | Toshiba Portege M400 PPM40U01000E Tablet...
How to reset toshiba portege 3500 laptop password from bios
first remove the bios battry romove the mb memori ic 24c small 8 pin 3 and 6 to conat wire solder short wire power on you bios lock unlock be care full to work power on time.
Feb 22, 2012 | Toshiba Portege 3500 Tablet PC
Hi I have a toshiba portege m750 and my little brother was using it and I have decided to use it for college but the only thing is he cannot remember I was just wondering how would I go about changing the...
You can set a user password from inside Windows. From the configuration panel look for an icon that represents two persons and click on it. Follow instructions on setting a user password.
You can also set a password on boot but you have to be careful: If you forget it you cannot open the tablet to remove the password. You will need to take the computer to a Toshiba Certified Service Center.
To set the password on boot you can use the BIOS SetUp configuration or a Toshiba Windows applications (HRWset).
For Windows XP tablet PC edition 2005
If you have the CrossMenu application you can run the HRWsetup from there. You can also go to All programs, Toshiba Utilities and look for HRWSetUp.
For Windows Vista or Windows 7, the name of the application may be Toshiba Security Assist.
Be very careful. You must not lose the password
Jul 30, 2011 | Toshiba Portege M700-S7002 Tablet PC
Sometimes my screen goes off for no reason!
Check your settings in the display properties. The problem could be related to some display or power saver options. This applies if no reason means you do not touch your laptop when tthe problem appears. Otherwise it could be a wire problem as you have already supposed.
Oct 04, 2009 | Toshiba Portege R100 Tablet PC
Toshiba R100 suddenly very slow(!)
I'd suggest sending it back to where you bought it, this sounds a lot like a factory problem and it should be covered under warranty.
May 27, 2009 | Toshiba Portege R100 Tablet PC
Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
Mar 08, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
Usb cd rom will not boot can i boot from sd card
yes you must change the boot order and activate the legacy USB support if exsisted
Jan 25, 2009 | Toshiba Portege R100 Tablet PC
Laptop will not go in BIOS or boot up
We use these and several times I have had to pull the battery, disconnect the power cord and hold the power button for 30 seconds (count slow). After that, it boots fine.
Nov 10, 2008 | Toshiba Portege R100 Tablet PC
Screen problems on Toshiba Portege R100
Right click on the computer's destop and view the display properties. Under the tab where you can alter resolution you can manage multiple monitors, It sounds like your laptop is setup to display through it's external VGA by default. Click on the two squares it shows and try to set your main screen as default.
May 30, 2008 | Toshiba Portege R100 Tablet PC
Toshiba Portege R100 Tablet PC Logo
158 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
