Question about HP Laserjet M2727nf Multifunction Printer
I replaced the toner cartridge in the laser jet M2727 but it keeps giving me an error message: saying replace black cartridge, but it is printing fine
  • 18 Answers
SOURCE: Cartridge problem
the problem is that even if you dont use the color supplies they do have a life cycle clock, you could try reseating the cartridge but i doubt that will work. what needs to happen is that the chips need to be reset or replaced on the color cartridges, its cyan now soon it will be yellow and then magenta. you can 1) replace the cartridges with new ones orr 2) have a cartridge refill place replace the chips on them. they dont need to be refilled unless the toner from age and humidity became soild. what most people dont understand is that if all you print is black then dont buy a color laser printer. toner over time can become a soild chunk and ruin your cartridge. most laser cartridges have a 2 year shelf life thats seald in a air and water tight bag in open air the toner starts pulling in the humid air and starts to become soild, this can take anywhere from a few weeks to a few years.
Posted on Sep 07, 2007
EPIJAB
  • 89 Answers
SOURCE: Refill Toner Cartridge for Laser Printer
I work for a company that does this and can tell you it is possible. Some companies do the drill and refill and some like mine actually take the cartridge apart and replace the drum and wiper blade.
You can buy the kits to refill your own. Usually, it just involves drilling a hole and pouring in the toner. This is the first I have heard of the melt and pour. Just be aware that eventually the parts inside will wear out and start to show image defects. You don't recommend reusing them more than twice.
Posted on Feb 15, 2008
hvpatel
  • 152 Answers
SOURCE: HP Laser Jet 3055- "No print cartridge" message
there is contact problem first you see your cartridge metal parts
both side of cartridge your matel part connect your printer metal parts{both side inside the printer} need to clean printer metal parts clean with clothes
Posted on Feb 28, 2008
  • 108 Answers
SOURCE: Toner empty message
I would try to unplug the printer and leave off for a few minutes. and see if that resolves the problem.
Posted on Jul 30, 2009
don_farr
  • 1011 Answers
SOURCE: Black toner replaced; now all black printing comes out faded grey
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Posted on Mar 03, 2010
HL-2280DW says replace toner but I already have
Just do a manual reset:-
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Original Brother tonor cartidges should reset automatically.
Apr 17, 2014 | Brother HL2280DW: HL-2280DW Wireless Laser...
Printer prints but the paper never comes out
There is a piece of debris blocking the paper from exiting.
Try feeding the paper backward to catch the obstruction.
Mar 15, 2013 | HP Q7553A black toner cartridge for laser...
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
Printer keeps saying to clean the corona wire. I cleaned it several times but the message keeps popping up.
To clean the corona wire in the brother laser printer, it said to remove the drum/toner assembly from the printer. This is very easy to do, you simply pull down the front of the printer, and press a small green tab down and pull. Then the toner and drum assembly will quickly come out.
After that, it says you must clean the corona wire by moving a small green square back and forth several times. It seemed kind of strange to me, but I did it anyways. In the upper right corner of the drum/toner assembly, there is a small green/blue square that can be moved back and forth. I did this several times.
I then placed the unit inside, and the error message went away for a minute. However it still wouldn't print and the error message came right back up. I was a bit frustrated since I have only owned this printer for about 2-3 months.
But then I realized something: The toner button had been blinking for about a month. I had already purchased a high yield black toner cartridge for the brother laser printer (Tn-330/TN360). I purchased it online, and had it stored for when I eventually ran out of toner.
I thought perhaps the error message had something to do with the old toner. Maybe it was out?? So I once again opened the front of the laser printer, and removed the toner/drum assembly. I pressed a green tab, removed the old toner, and then added the brand new high yield black laser toner cartridge. The whole process was very simple (you gotta love today's technology).
I then quickly "cleaned the corona wire" a few times again just to be safe. I re-installed the toner, and the printer was up and running. So apparently it will throw this error when you are out of toner. Now the printer is running great again, and I really like this printer.
If you are still using an ink jet printer, then you are living in the stone age. I was reluctant to buy a new laser printer, but now I love it. The toner only costs $30-60 and lasts for months. I print hundreds of labels out each month-just to give you an idea of how long it lasts.or get more information Call +877 889 6859 for detail.
Jan 04, 2011 | Brother HL-4040CN Laser Printer
Hello, I am using the Ricoh Aficios SPC232SF all in one printer and the starter toner has run out (apparently the black is only good for 1000 pages). I have ordered a replacement but in the mean time it...
Hi, unfortunately you can't make any copies or prints when the machine is out of black toner. If you still have the toner bottle, you could try gently shaking it and reloading it to see if the machine can squeeze just enough toner out to keep you up in the meantime.
Dec 30, 2010 | Ricoh Aficio SPC232SF All-In-One Laser...
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
HP Laser Jet 4250/4350 series says its ready then it prints blank page and sends a message 51.20
Try a replacement toner cartridge first.If this fails, then i suspect it's a laser scanner fault. The error denotes beam detect error which is more than likely a laser scanner fault
Oct 12, 2009 | HP Office Equipment & Supplies
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
HP Laserjet M2727nf Multifunction Printer Logo
804 people viewed this question
Seeker5211
Seeker5211
