Question about Whirlpool Duet GHW9150P Front Load Washer
Washer displaying F35 error message?? - Whirlpool Duet GHW9150P Front Load Washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
F35 Error
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Posted on Dec 31, 2010
Ok I had my pump replaced a few weeks ago but now I am getting the sud and f35 and f28 messages. What shouli do anjow much is the switch?
Try this one to remove the error display f35 and f28
Press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
Jun 03, 2011 | Whirlpool Washing Machines
Getting an F35 error message on a front loading kenmore washer. Any suggestions?
This link should help:
http://www.managemylife.com/mmh/questions/123674-does-f35-error-code-indicate-kenmore-front-load-washers
May 20, 2011 | Kenmore Front Load Washer
My whirlpool duet washing machine displays code F35 and won't complete the washing cycle.
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
In some cycles the word sud appears on the display. Then the cycle will stop and F35 appears on the display.
one of our techs has already answered this on the f35 error code click here http://www.fixya.com/support/t400054-error_code if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
p.s to repair this issue you would replace the analog pressure switch the switch's part number is W10156252
Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f35 mean
Hello there
F35 found in this link
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
F35 means ANALOG PRESSURE SENSOR FAILURE
1. Check if pressure hose is fixed correctly.
Dec 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Getting error message #5UD and F35
F35 ANALOG PRESSURE SENSOR FAILURE
IF YOU GET ERROR MESSAGE SUD
SUD error message, and are observing some water in the tub that is not draining at end of cycle, and your washi cycle is taking a lot longer that normal to complete,then here is what to do.
Please rate this solution
RNJ VINODKUMAR
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
