Question about Epson Stylus Photo R320 InkJet Printer
How do i change the ink cartridge - Epson Stylus Photo R320 InkJet Printer
I am having problem on how to change the ink cartrdges. I can't get it to go to the center to be able to change the ink. Pls. help
hi,
following images and steps may guide you.
first know the parts.
Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
Remove and discard the orange cap.
IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
Insert the black ink cartridge into the printhead. User's
Press down on the ink cartridge until you hear it snap into position
Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
Insert the color ink cartridge into the printhead
Press down firmly on the cartridge until you hear it snap into position
Close the printer access door.
regards,
cseian
Feb 16, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer doesn't revognize new ink cartridge
Are you using Dell Series 5 ink cartridges? Dell Series 5 ink cartridges have a cartridge that cannot be reset.
Article on refilling Dell ink cartridges
It's possible to get a bad Dell Series 5 ink cartridge. Return to place of purchase for a replacement.
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I do not know how to change the black ink on a monolta 2300 ?
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/0/70744652a954e650c1256f820078e0a2/$FILE/MC24x0-Replace%20Toner%20Cartridge.pdf
Goto the above link and it shows the PDF doc. for changing the cartrides.
Jun 23, 2009 | Konica Minolta magicolor 2400 Laser...
Changing ink cartridge
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 05, 2008 | Epson Stylus Photo R320 InkJet Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
