ONN ONDS-19 If it is possible, how do you change the clock from 24 Hour to 12? The instructions say nothing & nowhere does it say it is a 24 hour clock.
SOURCE: 24 hour clock
Press and hold the time button til it flashes 12H.
Posted on Dec 11, 2007
SOURCE: change the time setting from 24 hour to 12 hour AM PM
Check this
Go to start>settings
Go to the system tab and the regional settings icon
Go to the time tab and it should be hh:mm:ss tt for 24 hour clock
Let me know how that works out for you
Posted on Mar 06, 2009
  • 2501 Answers
SOURCE: coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
Posted on Feb 03, 2010
cmcduncand
  • 714 Answers
SOURCE: how to change from 24 hour to 12 hour on g shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 19, 2010
SOURCE: How do I set a seth thomas weather station from a
Press and hold the mode button until the year starts flashing in the upper left. Tap the mode button 3 times. You will see "24hr" with the 24 flashing. Press the + or - button on the back. Press the mode button 4 more times (or just leave it alone for about 30 seconds and it will go back to the normal display).
Posted on Apr 08, 2010
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
Cant change clock from military to 12 hour
I don't know which brand or model your were talking about, but usually if you press and hold the clock button down, it will change from 12 hour to 24 hour (and back).
Nov 08, 2016 | Kitchen Ranges
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
Apr 06, 2016 | Brookstone Audio Players & Recorders
How to change from 24 hour time to 12 hour time
The change from 24 hour to 12 hour display is semi hidden. I found the instructions and followed the set up, this change follows the settings for minutes in the sequence, so right after you set minutes on the clock push up or down and that will change the 24 hour clock.
Mar 07, 2014 | dr. Tech WF-1070T Home Wireless Weather...
How to i change my onn onds-19 clock to pm?
If you figured it out please tell me. I have the same problem.
Feb 07, 2011 | Audio Players & Recorders
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
I have the georg jenson wave clock but don't know how to toggle between the 24/12 hour clock. Right now it's set for the 24 hour clock and I live in the U.S. and want the 12 hour clock setting.
Well...this solution may be a few years late for the original poster, but I did figure it out on mine. If it's the same clock that sits on a rubber stand and you press the top edge back to activate the light, to toggle between 12 hour and 24 hour clock, you press the + and - buttons, simultaneously, for 3 seconds.
Jan 19, 2010 | Jensen Audio Players & Recorders
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Clock format
24 hour mode is all there is. Time to learn military time.
Feb 11, 2008 | Protron PD-DVR100 DVD Recorder
218 people viewed this question
 Grubhead
Grubhead
