Question about Motorola CP185 (16 Channels) Two Way Radio
I have two motorola cp 185 radios. I was using one with the external mic plugged in yesterday and now when I disconnect the mic I don't get any transmission. The other radio can hear the talk button being keyed but no voice transmits. If I plug the external mic back in then it works fine again. Is there a mute switch that I have engaged or what?
  • glawley Jan 05, 2011
    Yes, this seems to have fixed the problem.
  • 2,069 Answers
Your unit is stuck in the external mic mode. when external mic is engaged, it automatically re-routes input to the external device. this situation can happen if such an external device has not been used on the unit in a long time. i would consider this a hardware issue rather than software. solution may be to open (dismantle the radio) and clean at the interface / jack for the external connection. this should sort it out.
regards
Posted on Jan 02, 2011
My cb motorola can't receive from other cb radio
make sure that it is a cb radio and not a business band radio
Apr 22, 2014 | Cobra 29 LTD CB Radio
Do you have diagram and pin cofiguration of mh66a7a external mic and speaker. Or pin configuration of external mic and speaker for my unit vertex vx 824 . Because i want to modify using motorola external...
Hi Jan,
Try the following: join yahoo group Specific to your radio Make & Model, you will need to provide as much info as possible to the team there so they can assist you, you can also download manuals, diagrams and other goodies for your radio(if available) and all this is free.
I hope this is useful to you and thanks for your query to FixYa team.
Cheers,
Peter
Mar 18, 2013 | Yaesu Radio Battery Charger Vx-824 Vx-929...
How can I tell if my Motorola CP 185 is UHF or VHF?
The model number for the UHF begins with AAH03R, and VHF begins with AAH03K.
Also, a quick indicator would be the antenna, if it starts out thick at the base and tapers to thinner than an ink pen, it is UHF. If the antenna is thick like a kindergartener's pencil, it is likely VHF. (Exceptions to this would be if you are using a 3" stubby antenna, and in that case they are all thick.)
Best regards.
Jul 10, 2012 | Radio Communications
I need to wire external speakers to a Motorola XPR 4350
usually when buying a 2way radio they come with a headset (a headphone and a mic) all you need to do is cut the mic and headphone off using the wires for the headphone solder them to a speaker.
(the higher the power of the speaker the more it will drain your battery)
Mar 22, 2011 | Motorola Talkabout SX900R Two Way Radio
Motorola cp200 attached microphone will send but will not recieve
Assuming you have the correct mic for the radio (HMN9030 or PMNN4013). It is possible
1) you have accidentally plugged the mic into the radio with the radio turned on, (this will cause the radio to receive but not transmit. It can simulate VOX.)
2) you have a bad audio accessory jack,
3) you do not have the mic plugged all the way in (you will feel a slight click when the mic is seated properly)
4) you have a bad mic or bad mic cord.
Possible solutions:
1) With the radio turned off, replug in your mic (feel for the click), then turn your radio on, and see if it works.
2) Try a known good mic from another unit.
3) If none of the above solve the problem, send your radio along with the mic to a repair facility and have the jack tested. (FYI: Flat rate repair on this style radio is currently around $85. Cord replacement on the mics can average $27 to $38.)
Feb 03, 2011 | Motorola CP200 Two Way Radio
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
Motorola SX700 battery drainage w/tactical mike
It is likely the mic set you are using is not made for the SX700 radio, and is drawing too much power from the radio. Some audio accessories draw more power than others. It is possible your mic set is intended for a professional model radio which would supply more power to the device. You should check with Motorola to see if they have a mic set similar to go with your SX700 radio. Here is a link to their online store: http://www.store.motorola.com/mot/en/US/adirect/motorola;jsessionid=130652F39955D9E9CA94908C45C73822.mot3?cmd=catDisplayStyle&entryPoint=adirect&catKey=601560&messageType=catDisplayStyle
Oct 18, 2009 | Motorola SX700R 12-Mile FRS/GMRS Radio...
Transmit button on the lapel mic will not key the radio
Two things which come to mind, one would be if the PTT on the remote mic is bad/defective, second would be you are plugging the audio device in with the radio turned on.
If your remote mic is failing, the PTT is a repairable item, as is the cord on most models.
Mar 30, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
Ear bud/ptt, not working
Two things to check for:
1) The radio is shut off when you plug the earpiece into the radio.
2) Your VOX feature is shut off, or set to zero. (The XTN radio will sense an audio device is plugged into the jack and sometimes cause problems such as you are having.)
Lastly, be certain the accessory is designed to be used with the XTN style radio.
Nov 21, 2008 | Motorola XTN and Spirit Pro Replacement...
Push to talk problem
If indeed radio #1 has a mic problem, this may be confirmed by trying an external speaker/microphone plugged into the accessory jack. If still a no, then its not the mic but possibly the modulator circuitry. If there is transmit audio with the external mic and hence internal mic is defective, the unit would have to be pried open and the defective component replaced. The internal mic is normally an electrofet 2-3 terminal soldered to a shielded wire and physically attached to the front plate.
Alternately, another possibility is that radio #2 has its Interference Eliminator Code enabled/activated. This is indicated by the presence of small sized digits on the top right of display. If this is the case and no similar digits are displayed in radio #1, then radio #2 will not allow any received transmission to be heard. Along the same line of reasoning, if the code is activated on both radios signified by the presence of the 2 small digits, and radio #1 has a problem with its CTCSS (code) generator, then it would also prevent reception of radio #2. A way to verify this is by deactivating/disabling the Interference Eliminator Codes on both radios.
On certain occasion, it is also possible that radio #2 has a defective speaker. You should be able to verify this by plugging in an external speaker to the accessory jack of radio #2.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 09, 2007 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola CP185 (16 Channels) Two Way Radio Logo
124 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
