The problem is E 5 i cant print or use the scanner or make photocopy what i do
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 544 Answers
If this is a canon printer.
E5 error occur with no ink cartridges installed in the printer.
This is the first alarm that will appear.
Other alarm are E4 ,E7, E1,4 ,E1,5
It seem that the printer is not detecting the ink cartridges.
What you could try is to remove both ink cartridges and unplug the printer.
Wait 10 minutes, this will discharge power to printer for printer to reset.
Also for printer to cool down if the error is cause by overheating
Plug printer back into outlet, turn on and install ink cartridges.
Posted on Dec 31, 2010
Canon ir 1024 photocopier photocopy but the paper is blank what can be the problem
if print from computer ok than problem on scanner or both blank problem on high voltage
Jul 20, 2016 | Canon IR1024 COPIER FOR 220 VOLTS
I need a software that can enable me print from my 26 bit computer and my copier AR-M207 PHOTOCOPIER
You can download a printer driver from here.
http://www.sharp-world.com/support/download.html
Microsoft is ending support for Windows XP so I would suggest updating your operating softwaere.
Mar 09, 2016 | Sharp Used AR-M207 Copier Printer Scanner
Have more lines what I do
More lines when printing or photocopying?? What color lines? For lines when printing, clean charge rollers of the respective PCUs. If not, replace PCU drums. For lines that are appearing only when photocopying, check if the slit glass or flat bed glass have white out liquid correction ink markings on them. If yes, clean them. If not, clean scanner lens and mirrors of the scanner assembly.
Mar 11, 2014 | Ricoh Aficio MP1600SPF Copier
Preventing barcode scanner from rading photocopied barcode
put a red background, so that b/W prints will be black. Nothing can prevent color copies to be made though...You casn always develop an app for validation.
Feb 24, 2014 | Datalogic QuickScan Computers & Internet
HOW DO I MAKE A COPY FROM A COPY ON MY HP 2420
You cannot make a copy if you are thinking of it like a photocopier. It doesn't have a scanner built into it .
If this is what you are thinking there are several quite excellent scanners out there fairly cheap. The scanner will come with software that will make it and the printer behave like a photocopier. The scanner we use at home even has a button that we just press to scan and print a copy as well as software that gives more options.
If you want to just print multiple copies of the page then this you can do. You just have to go to print options on a program menu and tell it to print the page how many times you need. You can also change the number on the printer driver but if you don;t set it back after everything after is going to print a few extra copies.
Sep 13, 2011 | HP LaserJet 2420 Printer
How will you compare and differentiate a scanner from a photocopying machine?
scanner copies the doc but photocopier scans and prints thats it
Jun 22, 2011 | Computers & Internet
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
May 04, 2009 | Office Equipment & Supplies
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Cannot scan to pc
my MP 160 cannot scan to pc, but can print and photocopy well. it says it cannot communicate with scanner..cable might be disconnected or scanner might be off..tried uninstalling and reinstalling..still doesn't work
May 21, 2008 | Canon PIXMA MP160 All-In-One InkJet...
k24674
jasbo
jasbo
