Question about Whirlpool Dryers
IN THE MIDDLE OF DRYING A LOAD IT STOPPED AND NOW WILL NOT START AGAIN
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 31, 2010
How do I fix dryer that stopped working?
Check the little button that the door pushes in when you close the door (door switch).
May 01, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Checked fuse box, good, checked plug in, good, door shut, good, dryer won't start, was in middle of drying load, stopped. Won't start.
may be door switch, here is a website that will help, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 07, 2010 | Kenmore 69101 Dryer
My dryer just stopped working in the middle of drying a load of clothes. now it doesn't do anything when I press teh start button. I've checked the circuit breakers, power ,etc.. any suggestions?
Is the motor still running...did you check that?
If the motor is running then sounds like you have a broken belt or a belt that has slipped off the pulley of the motor
Sep 25, 2009 | Estate Dryers
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Shaun
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
