Digital display "04" on Friedrich
  • 2,133 Answers
04 -Indoor coil thermistor open short circuited. Replace it.
Posted on Jan 01, 2011
On a Friedrich in wall AC/Heater in the heat mode in the digital display while the unit is working fine I get a flashing 08 alternating with the temp of 74. Model # PDE15K5SB-A is this a trouble code
This is an error code for "Unit cycles more than 9 times per hour". The service manual says the possible causes are "Unit oversized" and "Low load conditions".
Jan 10, 2015 | Friedrich Heating & Cooling
Describe your KS15L10 Thru-Wall/Window Air Conditioner Problem My unit also runs about 10 minutes and the kick off the 15 amp breaker. Unit was purchased 2006. Any ideas
Hello my name is Heath iot will be my pleasure to assist you. The first thing to do is unpludd the unit then go out side wioth a garden house and use a strong jet of water and blow it through the coil and get it real clean if you can then try running the unit.
Aug 29, 2011 | Friedrich QuietMaster KS15L10...
I have a Friedrich thru the wall air conditioner with a wall mounted thermostat but I cannot seem to regulate the temp. with the thermostat. What happens when I press the up and down arrows.....does the...
It is not uncommon for the room temperature and the set temp. on the thermostat to be several degrees apart. The room temperature should go down when you set the temperature on the thermostat down to a lower number.Hope this helps you and thanks.
Aug 17, 2011 | Friedrich Heating & Cooling
Digital keypad does not respond on Friedrich through the wall AC ("Weathermaster). If I hold down the "cool" button for several seconds, I get E-2 display.
First, check the reset switch on the power cord. If after holding it in for 2 seconds, the unit does not reset itself, it means that you will need a service call. In addition, I have looked over the Owner"s Manual for you model, as well as the Service Manual and no where can I find a reference to an E-2 display on your LED screen. If resetting the unit does not solve the problem. Contact Fredrich's Customer Support Dept (800) 541-6645.
Jul 06, 2011 | Friedrich CP08N10 Thru-Wall/Window Air...
Thru the wall air conditioner is leaking droplets of water from between the frame and the body
Your unit should be pulled from the wall and cleaned. Also Check with a level that through the wall sleeve that the unit sits in has a slight lean towards the outside and not inside.
Jul 05, 2011 | Friedrich Heating & Cooling
Electrolux Icon side-by-side E23CS75DSS - repair man replaced the defrost thermostat and now the digital temp display flashes. The freezer temp display flashes "E" and the fridge display flashes...
Sounds like you have a evaporator fan motor. That is what the error code you have indicates, the fan blade could be stalled to.
I work on these units every day and know them very well, I can walk you through any repair on this refrigerator.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
TCL-12 CHE/s Mid-wall split unit. The unit is fully operational. The display on the front panal "jumps" - the room temperature display temperature "jumps" Thanks Harold
Clips with PCB loose contacts. Find and rectify. If not clean with blower with minimum speed. Dust forming on display sensor will create these type of jumping.
Jan 19, 2011 | Heating & Cooling
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
Squealing and sometimes doesn't blow cool
A squealing noise is most likely the bearings going bad in the blower motor. This will slow the motor down. If the blower is not operating at the proper speed this will affect the temperature pressure relationship of the refrigerant. This will cause the unit to put out the wrong temperature. Running the unit to long under these conditions can possibly cause further problems ( including a very high electric bill). I recommend that use do not use this unit untill it is repaired or replaced.
Good luck.....
May 03, 2009 | Friedrich M18CF Split System Air...
Heating & Cooling Logo
146 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
