Question about Car Audio & Video
I hae a 2001 Chevy Tahoe, I am unclear what size sub is mounted in the back on the drivers side. I have heard 8" and 10". What is a good aftermarkey sub that will bolt right in? what size is the factory amp that is pushing that speaker?
    Scholar:
  • 127 Answers
Http://www.scosche.com/vehicle.search.results/?applicationGuideID=7920%0D%0A&make=CHEVROLET&year=2001&model=TAHOE
this will show you your make and model and all the parts and speaker from scosche
they say you have a 8" in the rear for sub
http://www.tintingbyfredjohnson.com
Posted on Dec 31, 2010
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
I have a 97 Chevy Tahoe 4x4 350 vortech, what wrench size do u use to take off my fuel filter ,that is the line going in.?
it just a basic tools. find the filter and see what size it is.
crawl under the truck on the driver's side, follow the fuel line from the fuel tank to the filter(shape:cylindrical).
make sure the line has no pressure. you should pull the fuse for the "fuel pump" relay, then start the engine and allow it to stall.
Mar 02, 2012 | 1997 Chevrolet Tahoe
Change order for 5.7 liter chevy tahoe spark plugs
You can replace them in any order, but the Firing Order is 1,8,4,3,6,5,7,2
Aug 30, 2010 | Chevrolet Tahoe Cars & Trucks
2001 Chevy Tahoe, Heated seat back works but not seat bottom.
Open drivers side door and look at the end of your dash board that is faceing the door.You will see a little triangle shaped door that pops out.There are also more under the hood,drivers side in a big square box.Behind the batterie.
Dec 30, 2009 | 2001 Chevrolet Tahoe
Is there a huel reset on 2001 chevy tahoe
Sorry there is no fuel pump reset on the Tahoe. If you have no fuel pressure, check the fuses and relay,and wire harness to the fuel pump from the inside frame rail on the drivers side. If you can hear the fuel pump working, check the fuel pressure at the shredder valve and there should be 60 to 66 PSI, if you don't you can try checking for 12 volt at the fuel pump wire harness at the frame rail. Good luck and keep me posted, be glad to help.
Jun 06, 2009 | 2001 Chevrolet Tahoe
2001 Chevy Silverado anti-lock brakes activate on dry pavement, the pedal pulsates, the typical anti-lock brake sound is heard, and the truck feels like it is not going to stop at times
One of the sensors has gone bad and needs to be replaced, the other thing to that would also do that is the ABS sensor is dirty or needs to be re gaped to the speed ring on the hub. There was a issue bulletin with your Tahoe on the ABS activating under 8 km/h. Good luck and hope this helps, if not clean out the sensor with brake parts cleaner and check the wire harness and ABS sensor bracket. Re gap the sensor to the speed ring hub. Here is the bulletin. Anti lock Brake (ABS) Activation at Low Speeds (Clean Wheel Speed Sensor Mounting Surface) #03-05-25-007C - (05/16/2006) 2001-2006 Chevrolet Suburban, Tahoe
Jun 05, 2009 | 2001 Chevrolet Tahoe
Need to replace passenger side mirror on 2005 chevy suburban
you need a flat screw driver to take off the cover inside, then there's a not in there size 10 or 8 mm you just need a wrench for that size that's all...
Apr 21, 2009 | 2001 Chevrolet Suburban
Driver side power seat 2001 Chevy Tahoe
as long as nothing is stuck in track and you hear no noise when using switches, look for broken wire at connector or in harness. ck fuse first of course, if blown, something may be stuck in track causing it to stop and blowing fuse
Nov 15, 2008 | 2001 Chevrolet Tahoe
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
