Your WLAN card has stopped working properly. This is a network adapter that allows your computer to connect to a wireless network. To find out if an updated version of your WLAN card is available, contact your device or computer manufacturer. How do I find my computer manufacturer? Click the Start button , type msinfo32 in the Search box, and then press ENTER. Your computer manufacturer is listed as the System Manufacturer in the right pane of the System Information window. this is what my laptop is saying how do i fix it
  • 83 Answers
Go to the device manager look up your card,first update the driver by right clicking on the card that is in network adapters.if that doesn't work try removing the card and let windows re-install it automatically.If that doesn't work go to best buy or office max and pick up a pcmcia wireless network adapter or a usb wireless network adapter about 12 -$19.00
Posted on Dec 31, 2010
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
-unable to connect to wireless -unable to open internet explorer msg states "unable to connect due to error on this site" (yahoo) -Is there a reset botton for wireless -Called my internet Co,...
Your problem may appear from a not properly enabled WLAN card.
Make sure the Wi-Fi swithc is in ON position and on your laptop keyboard try the FN+F8 combination to have displayed the wireless card status. The WLAN card has to be ENABLED to be able to connect to the Internet. The combination done will make appear on your display a window with some options available; choose that option that enables your wireless card.
Also check in your computer's DEVICE MANAGER if your WLAN card is working properly. To do so follow these simple steps:
1. START and click on SYSTEM;
2. in SYSTEM option click on DEVICE MANAGER;
3. on DEVICE MANAGER option go at NETWORK ADAPTERS and see if there your wireless card is indicated and it shows that it is working PROPERLY;
4. if an UNKNOWN DEVICE is indicated then try to find the right driver for you notebook model and WLAN card model;
5. install the driver then REBOOT and recheck in DEVICE MANAGER if your WLAN card is displayed properly this time.
Mar 02, 2011 | Toshiba Computers & Internet
How do i download network adapter for my dell tower, its service tag is C0WST21
please page the URL below in your browser and click download button.
http://download.cnet.com/Network-Dell-Wireless-US-WLAN-Network-Adapter-Card-Wireless-1370-802-11-b-g-WLAN-MiniPCI-Card-Wireless-1350-802-11b-g-WLAN-miniPCI-Card-Wireless-1450-802-11a-b-g-Dual-Band-WLAN-miniPCI-Card-Wireless-1350-WLAN-802-11b-g-PC-Card-TrueMobile-14/3000-2112_4-109107.html
Feb 19, 2011 | Dell 04U852 Network Adapter
I have a similar problem. I have a button to switch on the WLAN card, which has always worked before. I would press this and the WLAN status LED would come on, and off I went browsing. But all of a sudden,...
can you check on your computer whether you got the drivers of WLAN or not - give a try with these few steps please
1. device manager (right click on my computer icon on desktop and select properties - select tab hardware - select device manager ) and check in the right pane for network adapters , under network adapters ull find the wireless name , check the status by double clicking on it .
2.go control panel -network connection (for xp ), network and sharing center - manage network connections on left (vista) , network and sharing centre - change adapter settings on left (win 7) and please check for wireless adapter status -says enable or disable
make sure both are enabled and then check with the wifi switch on your machine .
Oct 04, 2010 | Systemax Neotach 3300 Notebook
The linkssys usb adapter does not connect automatically to the WLAn router. it always says "win xp manage the wlan" but this is not true
the problem may be caused by the installation of the usb adapter's WLAN software (WinXP already has a built-in WLAN). Ty uninstalling the adapter's WLAN monitor, unplug and replug the USB adapter to your computer and it will be installed automatically. Once installed, Go to Control Panel >> Network Connections >>Right click Wireless Network Connections and click View available wireless networks. Try manually connecting initially to the router and see if it will be automatic from then on.
Jul 05, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Wireless networking hardware not functioning properly.
Check on Device Manager if it is working properly
Right-click My Computer-Properties-Hardware-Device Manager
Click on the plus sign beside Network Adapter and double-click your wireless card.
Check on the device status if it says it's working properly.
Try to disable-enable the adapter by right-clicking on it under the device manager window.
If it has a question mark, it is most likely driver issues so contact your wireless card manufacturer or PC manufacturer if the wireless card is built in.
Jan 12, 2009 | Gateway MX8711 Notebook
Wlan W200 connection problem
There is a solution to this, and you won't have to buy a new card. The folks at HP, however smart in their design of this laptop, have not properly updated the bug fix for the wlan w200 drivers. What you'll need to do is actually take back your network adapter driver all the way back to Version 1.0 revision C. I did this with an n610c that I got for free because it was BSOD'ing every time the wireless was turned on. For the most part the wireless can handle older routers and wlan areas, but will BSOD when within range of a wireless "N" adapter. Simply download the driver version 1.0c and you should have no more issues.
Tip: You can disable the card manually by pressing your "Fn + F2" keys, rather than trying to navigate your menus before getting the BSOD.
Nov 07, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
