Question about Kenmore Dishwashers
Kenmore Elite Ultrawash, possibly 11 years old, 665.155962990 toxic burning smell pumps and electricity work reading reviews for new dw's inclines me to want to have a repairman try - if the odor is not a dead giveaway to junk it THANK YOU
  • 11,896 Answers
If you have a belt on this machine, I would change it. If the tub bearings are worn, then the motor will spin the belt faster then the tub/drum can turn causing burning. Worn pump or tub bearings can also cause this smell. Make sure pump is clean and tight.
Posted on Dec 31, 2010
  • perville Jan 06, 2011
    Thank you, Minnesota fisherman,
    I have no idea yet, but have called a repairman rather than buying a new machine.
    There is a post holiday wait to get a good repairman in my area.
    Thank you for contributing with infromation on my dishwasher.
  • Nate Stansfield
    Nate Stansfield Jan 06, 2011
    Not a problem at all. If you feel up to it, let me know what you find out. If you have any other questions, feel free to ask.
My kenmore elite calypso will not do final spin.flashes LD. I replace the pump as was suggested,still did not fix froblem
Hello Alex;
My name is Peter. I am a retired field service appliance technician.
After review of your washer components, there is a strong possibility that you have a bad electronic control board. You have two control boards, one is for the motor and one for the other functions.
Washer electronic control board for Kenmore Elite Washer model #11021062001 Electronic control board 8571359 is the circuit board that manages the washer's functions, such as filling, washing, draining and spinning. It sends voltage to the drive motor and other electro-mechanical component.
Cost: $218.00
If you elect to replace the board make sure you ground yourself by rubbing your hands on something that is bare steel. Static electricity will knock a board out.
All appliances with electric control boards should have a surge protector. You can purchase a wall socket surge protector for $20-25.00. It is a good investment considering how expensive control boards are.
Rule of thumb; "If the unit is either 7 years old or the cost of repair is 1/3 or more of the original price, purchase a new unit.
Consider it purchasing a new unit, stripping your existing unit for parts to sell on e-bay. You will make a little money and save others expensive parts cost.
Dec 03, 2014 | Kenmore Washing Machines
Water is pooling in my kenmore ultrawash and it won't turn on either. I need to know if there's anything I can do to drain the water because I think it's refusing to turn on on account of that water p
First unclog your sink drains and the drain hose from the dishwasher. Once you are certain they are clear... Then you can do a couple things to remove the water. dip it out, or siphon it out.... or perhaps use an electric pump.
Dec 01, 2014 | Kenmore 24 in. Elite UltraWash Built-In...
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer has a burning smell. repair man came and looked at it and said mechanically the dryer looked brand new (its only 11months old). He suggested we repair the exhaust tube and vent (which we did). ...
do you have pets ie a dog that moults, as quite often its is foung that pet hairs get inside on the elements and cause a burning smell. if so disconnect from supply. Remove back cover by removing screws and hoover the elements. Make sure electric is off hope this info is useful.
Dec 16, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Burning compressor - repair or replace?
Take the old unit to sears and they have a repair kit for about $65 canaidian.Easy to fix,but replace any burned wires b4 putting unit back together.
DW
Apr 19, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
Kenmore Elite DW Water in bottom of unit and control panel not working @ all
happy new year,,ok easyas we go..first we must know if we have electricity,,,you must check at connection box under dishwasher,,,next we want to check or ,,door switch.....weel after that if it did not start,,im here...onthejob
Dec 31, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dishwashers Logo
101 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
