Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Need to set time an date. Can't figure it out.
Instructions for Armitron All Sport 40/6623 time setting needed.
Here's how you set the 40/6623 M175 for anything. I figured it all out with help from here :). Okay so want to set the alarm? Press MODE once. Then hold it. And use the DATE and ALARM buttons to set the alarm. Press MODE twice and you're done. To set time do the step before this and press MODE once. Use the DATE and ALARM button to set the time. As for the 24 hr deal what you do is hold ALARM and press MODE or hold MODE and press DATE. To turn alarm on/off hold ALARM button and then press the DATE button. To set the date go to time set mode and keep cycling between the hours and mins until you get to the date :). That's all you gotta do :D. I know many of you need the instructions so here it is!!
Apr 02, 2011 | Armitron Digital Sport 406623BLK Watch
I bought a samsung b3410 phone but can not adjust the time and date how do i go
I could not figure out how to set mine either, it kept telling me military time. Does yours do that or can you not get to the menu to set it. Ill tell you how i figured it out and hopefully it will help you. Go to Menu, Go to settings, go to set time and date, make sure it is not one 24 hour clock, change it to twelve hour clock then itll give you the option to set the clock right and the date. Hopes this helps. Sorry if it doesn't.
Jan 01, 2011 | Samsung B3410 Cell Phone
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
How do you set the date and time
You can download the manual at
http://www.home-electronics.net/ge/pc/IB/29875GE1_IB.pdf
Apr 02, 2010 | GE 29875GE Digital Answering Machine
I cant figure out how to set the time and date on an armitron mens M516 all sport 40/6753
I cant figure out how to set the time and date on the armitron instalite
Jul 08, 2009 | Bulova Watch
I am trying to set time and date on a calculator
OK, I bought one over the weekend just for chuckles. I figured it out.
On the top of the calculator there is a key that shows a little clock. Punch it once and the date appears...like 01-01-2000 or somesuch. Press it again and the time shows up..
Hold the time set key (=) down for a second until the first zero starts to flash. All you have to do is start punching in the time. When you are done press the time set key again. Voila!
Punch the key with the little clock again and the date shows up. Hold down the time set key for a second like explained above until it starts flashing. Enter the date with the key pad numbers. Done!
I couldn't figure this out either till I looked above each key (didn't notice what it said). Anyway, look real close.
Hope it works out for all and everyone finds this solution...
CMHIMG
Mar 04, 2009 | Canon P200-DHIII Calculator
I cannot set time and date help
I figured it out!!!! you push the time/date button once and then push the = (set) button and then it gives you the option to put in the day. Do the same thing again to put in the time also.
Jan 13, 2009 | Canon MP49D Calculator
Changing to correct date on camcorder
To change / reset date and time touch on lcd screen, HOME > SETTINGS > CLOCK / LANG > CLOCK SET and set the date and time.
Above said is mentioned in user manual of DCR-SR42 and you can download it from Sony Support.
Dec 03, 2008 | Sony Handycam DCR-SR42 Camcorder
Time and date...
you can fix or set the time at the setting menu. look for time and date settings. from there you can adjust the time and date...
Oct 27, 2007 | Motorola Mobility RAZR V3
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
