Question about Kenmore Washing Machines
Agitator slips sounds like plastic teeth are grinding
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Replace the "agitator dogs" with this part. Below is a video to show you how to do the repair.
Posted on Dec 31, 2010
The agitator on my Whirlpool (8280869) is rubbing/grinding. It seems the ratchet system is not catching on the center post when the agitator starts to spin. Can this be fixed?
On whirlpool/kenmore direct drive machines, the part you are referring to is the 'agitator dogs.' They are paisley shaped plastic pieces with teeth on the outer edge... Usually a 7/16 nut or a square plastic drive(1 inch socket adapter fits it perfectly) holds down the top half of the agitator. The pivot end of the 'dogs' must be inserted into their slot and should all face the same direction...
Apr 27, 2016 | Whirlpool Washing Machines
Grinder is not working. Makes a clicking sound
There is probably a stone jamming the grinding teeth. You need to take the top off the grinder and pick/vacuum everything out of in the grinding department. The top of the grinder has the stationary grinding teeth attached to it.
Oct 08, 2015 | Krups Coffee Makers & Espresso Machines
Whirlpool F65 6th sense Whitemagic top loader fully automatic - Cloth Mover (Agitator top assembly) slipping - India Model.
HOPE PICS HELP U MAY HAVE BAD AGITATOR COUPLER, BAD CAM DOGS, ETC
SEE PICS
In your case the cam dogs are repalced with this coupler.
Jun 06, 2015 | Whirlpool Washing Machines
I have an LG top loading washer, model WT4870CW. During the wash cycle the machine makes a grinding noise. The noise does not occur during draining and spin cycles. Any idea what could be the issue?
Is your agitator moving back and fourth, when on wash cycle
Could be your plastic agitator spline is stripped,
Take it out and check the plastic teeth is not worn inside.
Dec 25, 2014 | LG Washing Machines
Agitator just clicks when it should be moving. Will not move in wash or spin cycle. Please advise.
Agitator has 4 Teeth - Dog Teeth I Beleve the name is in top part of Agitator. Take softener cap off top of Agitator. There is a plastic cover under softener cap. You need to remove plastic cover then you will see 4 teeth that lock into the agitator replace all 4 teeth make sure you put the teeth back in the same way or it won't work. Old teeth are rounded and won't grab Agitator anymore. Job not hard.
May 17, 2010 | Washing Machines
Fisher and Paykel ECS Washing machine agitator slipping?
There are "dogs" under tops of some agitators. Easy to repair. ID them and pull up washing machine parts at Amazon. Dogs are by themselves(3 hard plastic gadgets) but better to buy the whole thing that hold the dogs. Usually under $10.00.
Apr 25, 2017 | Fisher Washing Machines
Our whirlpool 5232d top loader is making grinding noises at the beginning of the wash cycle and the agitator seems to be slipping on its spindle though a little further on into the wash cycle the grinding...
Sounds like a bad transmisson or you room temp is below 30 making the oil in transmisson like tar. Or its just the dogs or top gears in the adj.
Nov 11, 2009 | Refrigerators
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken
I have exactly the same problem as Jonthan, what's the solution?
Dec 24, 2008 | Washing Machines
Washing Machines Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
