Question about xheli S100 Syma 3 Channel Mini CoAxial Helicopter w LED Lights (Purple)
Hi i have a Syma S026 Micro Chinook 3 Channel Indoor Ready to Fly RC Remote Control Cargo Transport Helicopter, i used it a few times, and then the bottom rotor on the back stoped spining, and now it dose not lift up, i tried taking it apart but could not do it, can you help ?
  • 52 Answers
Unfortunately, due to the rush of Christmas, Syma enrolled two other companies to build their helicopters. I highly suspect that the model you have is one of the rogue models.
Your machine has a board fault that you cannot repair. It needs to be returned back to the store and replaced (should be free as the machine has failed, SO LONG as you have not crashed it or damaged the blades). It depends on how long you have had the machine.
Due to the nature of these micro-coaxial helicopter toys (yes, as harsh as that sounds, they are only cheap toys), the motors can also fail. This is due to the motors being 'ball raceless' and therefore due to their high speeds, they fail/fall aprt internally. The tail motor is the first to go on other micro's.
If the machine IS old, or you cannot find your receipt, then all is not lost. Just buy another Chinook S026 and keep the broken one for spares (blades, battery, shafts, etc etc).
Posted on Feb 13, 2011
I had one
Posted on Dec 31, 2010
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
Fully charged won't fly. s33 2.4g 3channel with gyro
If you've verified all channel settings and you're sure the battery is charged then it sounds defective. Is it within allowable time from purchase to exchange for a different one?
Jun 01, 2014 | Syma s33 3 channel rc helicopter 2.4ghz...
How do I change S022 frequency
They come set to a frequency the sticker on the helicopter and hand remote must correspond eg 27mHz both have to be same so if you wanted to change it you would need a new PCB circuit board and hand controller on the same frequency.
Kind regards, Julian
rccontrolfreak.co.uk
Mar 13, 2013 | SYMA Toys industrial Syma S022 Big Chinook...
Syma S026 instructions
We have a free copy available on our website.
Free Syma Helicopter Manuals
Kind regards, Julian.
Mar 05, 2013 | SYMA Toys industrial Syma S026 Micro...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
Hello, just been given a syma s006 for xmas, charged it up for max 110 mins as indicated in manual, though LED never came on to indicate full charge. LEDs do come on flashing when switched on at model. New...
try this,switch the helicopter on,then make sure the left controller stick is fully down then turn the controller on,move left stick fully on then fully off should be ready to fly,have fun
Dec 27, 2010 | xheli 3 Ch Syma S006 Alloy Shark RC Remote...
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
I need a new tv poloride flat screen remote control clicker
Howdy. To order a new remote control (clicker) you may call Polaroid at this number: 1-800-765-2763 (1-800-POLAROID)
If you prefer to write to them: Polaroid Corporate Office
4350 Baker Rd.
Minnetonka, MN 55343-8684
They should be able to get you one the fastest. Hope this helps:)
Aug 20, 2010 | SYMA Toys industrial RC Toys Village New...
xheli S100 Syma 3 Channel Mini CoAxial Helicopter w LED Lights (Purple) Logo
360 people viewed this question
Top xheli Toys Experts
MeAndMyBrain
Level 1 Expert
Tom Chichester
Rani wadia
Rani wadia
Are you a xheli Toy Expert? Answer questions, earn points and help others
