Question about Maytag Bravos MTW6600T Top Load Washer
Are there bumpers that line the outside of the drum? Sometimes when the spin cycle starts up it bangs along the front edge but no place else.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Open the cabinet and look at the "suspension rods" to see if one is broke or has come loose. Here is a link to the parts in case you need them.
Posted on Dec 31, 2010
My washer is making a loud noise during the spinner cycle. The drum is very loose.
Drum should be tight - noise you hear is the drum banging around all over the place as it spins.
Check the spindle and bearings where the drum is connected along with the tension on the belt that powers the drum.
Aug 29, 2015 | Washing Machines
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
With my Asko W6461, Right as the spin cycle starts, it sounds like something hard is banging against the drum (outside it) but inside the washer. Often, the spin cycle then does not complete. When I turn...
buy a new machine,the spider gear is broken and it's around 500 bucks for the part,you can buy a new washer for that,you used to much detergent,it eats at the metal on the spider gear and it falls apart,i've found parts of it inside the pump before.
Oct 19, 2010 | Asko W6461 Front Load Washer
Loose drum bangs during spin cycle turn by hand with nothing in drum and still bangs?
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Jan 25, 2010 | Frigidaire 14 Cycle Tumble Action Washer
On a flat floor but bangs and crashes when spinnig. Also the drum wobbles.
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Irregular banging during cycle
these washers are a swine to dis-assemble and i would not recommend it unless you are experienced. on most indesit, the bearings are in a spider bolted to the outside of the tub. take the back off and see if you can localise the noise to the bearings worthwhile also taking the heater out (one nut in the middle), peer in and check no foreign object causing the noise
May 21, 2007 | Indesit W 123 Front Load Washer
Banging during high speed spin cycle
Laco, drop the bottom front panel and see if all of the shocks are in tact on the tub assy. They just insert and lock by turning. If these are ok, check the back belt pulley. Sometimes one of the tines will split or crack and you will get this symptom. Catriver..post back.
Mar 04, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
533 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
