Question about Magix ENTERTAINMENT Music Studio 10 deLuxe ( Windows ) (26758)
Magix studio 10
I cannot figure out how to record to both channels- after I record from the mic- when I play it back it only comes out of one speaker- tried to go to wave editor, but I could not figure out how to make it paly in stereo from both speakers
The problem is you are only recording on one side if you are using only one source, try using dual mics (with a audio interface with at least 2 inputs) or just record your tracks in stereo, then change the playback prefference to mono for listening purposes, then change back to stereo before mixdown
Posted on Aug 08, 2008
When i record thru my mxl genesis mic with the mixer i get like a loud distorton. Im using magix 14 ,and i have downloaded the audio driver off the disc that came with the mixer....Help
It is likely you do not have the levels set correctly and are over driving the mixer. Reduce the trim settings using the PFL buttons and monitor the level indicators to insure you are not clipping.
With a condenser mic you CANNOT have any speaker in the room that the mic can hear of course. These mics are so sensitive. Your mixer and monitor speakers and recording will be in a separate room from the soundproof studio typically.
To monitor the system anywhere in the same room as the mic you MUST use headphones that do NOT leak sound or you will get feedback and distortion.
Mar 14, 2011 | Behringer XENYX 2442FX Mixer
I have Lexicon alpha, Condenser Mic, phantom power .If i record, the voice goes only to right speaker. I am using cubase le 4, stereo in/out are correctly.
Sorry, but the Lexicon Alpha does NOT have Phantom power and you can't use a condenser mic with it without a Phantom power injector or preamp.
If you mean you have a Phantom power injector then it should be working. Do you have seperate mics for the two channels of the stereo? If you have only one mic, then only one side will record unless you set for mono recording and then dump the recording into stereo voa Cubase. I would recommend you get a small mixer... even a 4 channel one to use ahead of the Lexicon so you can mix and PAN your mics the way you want them. The recording and trying to control the panning in Cubase can be frustrating... The Lexicon really doesn't have anything built in to PAN the mic to the center when stereo recording. Small mixers are inexpensive and often you can find them used or in pawn shops for cheap.
Feb 12, 2011 | Lexicon Alpha Personal Recording Studio
Whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
Recording conversations which mic to buy?
How many speakers?  In a room?  Outdoors?  What kind of recorder do you use?  What is your budget?  Hi Fi or just need to be able to recognize what is being said?
Depending on your setup you might try:
Solution one: lavalier mics like an Audiotechnica ATR35 on each speaker's lapel.
Solution two: a boundary microphone on the table, like Shure mx395.
Solution three: cardioid pattern mics pointed at each speaker (could also use a shotgun).
Solution four: one figure eight pattern mic put between two speakers facing each other (make sure the axis of the mic points at the two speakers).
Solution five: you could scrap your recorder altogether and get a Zoom H2, put all four channels on and don't thump the table.
May 16, 2009 | Sony Audio Players & Recorders
When i record my vocals its only in one channel why!
It seems that the recording input source is provided as "Line In" whereas you need to select the "Mic In".
This is because the "Line In" is a stereo input and expects input for both right and left channels whereas the "Mic In" input is a mono input which is the same as our default condensed mic device is.
By the way, you would be able to see the graphic VU meters while recording, weren't they displayed that the recording is done only for one channel ?
Always use VU meters for checking the levels for recording, they are available with almost all recording softwares.
Hope this helps.
Thanks
Mar 31, 2009 | Sony Acid Music Studio 7 Full Version for...
Similar Sound Problem...
Right click on the speaker icon on your task bar, select recording devices, from there you should see your mic inputs and change the levels through the properties button.
Mar 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
Magix ENTERTAINMENT Music Studio 10 deLuxe ( Windows ) (26758) Logo
181 people viewed this question
Top Magix Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
