Question about Dryers
Everything works properly accept for it just quit heating.......I'm guessing the heating elalament most likely went out?
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 31, 2010
LG DLE5001W Dryer Lights Up but won't accept programming commands or operate
I would guess new belt is slightly misrouted. From front, belt comes down left side of drum and goes around belt tensioner and then back to the motor pulley. Without the tensioner pulled to the left, the safety switch will still be tripped. Pulling tensioner to the left completes the circuit to the motor and allows motor to run.
Jun 23, 2017 | LG DLE5001W 7.3 CU. FT. FRONT LOAD...
Heat and climate control light not working
no, guessing either the control head or bcm went out of it
Jan 15, 2013 | 2006 Chevrolet Equinox
Lost power to ac/heat control.
prob. a bad a/c control head
Jun 15, 2012 | 1993 Chevrolet Suburban
Amana dryer NED7200TW quit heating, it appears everything else is working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Amana NED7200TW Electric Dryer
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
As soon as it warms up it dies (electrical?)
Yes , often times when electrical components are going bad , they start work until they hit a certain temperature then they quit. Most common items that quit with heat are pulsar pick-up coils , charge coils in the stator, CDI boxes, and ignition coils. Everything can be tested with a voltage meter accept the CDI box. The CDI box can test good and still be bad. You have to eliminate everything else first.
Sep 16, 2010 | 1996 kawasaki ZX-6R Ninja
Ge spacemaker quit heating everything else works
You megaton went out on you it will cost around 150 to replace it.
Dec 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My heat gauge quit working on my '91 Toyota 6cyl. engine. Is there a fuse for this? Where would I find it if so?
Is the Fuel gauge reading properly?
If so, the fuse is not blown; they are on the same circuit.
If the fuel gauge works, I would guess that you may have a bad temperature sending unit.
Mar 04, 2009 | 1991 Toyota Pickup
Heated Seat Quit Working
hi you should check the fuses first.look in your ovners manual or on the fuse panel lid and under hood fuse block/s for the proper fues and location.
Feb 02, 2009 | 2002 Chevrolet Monte Carlo
Heated Seat quit working
hi first thing you should do is check your fuses.check in your owners manual for the proper fuse and location.it maybe located in the car or under the hood
Feb 02, 2009 | 2003 Chevrolet Suburban 1500
Dryers Logo
49 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
