Question about Cuisinart CWC-1200 Wine Cooler
Im looking for a Board HS-PS12V70W-11 REV.01 for a WINE CELLAR CWC-600 of Cuisinart Could you tell me were i can obtain this part
3 Suggested Answers
  • 32 Answers
SOURCE: Cuisinart Private Reserve cwc-900 wine cellar stopped cooling
I haven't seen the unit you refer too but it sounds like many others that I have seen. The white stuff is heat transfer compound as used on CPU heat sinks, DO NOT WIPE IT CLEAN, if you have then it will need replacing. Check the fan is running at full speed to cool the heat sink that the plate is attached to. If there is no fan then there isnt much else that can be wrong with it apart from the control circuit, but that seems to be working as you say the plate gets hot.
Posted on Mar 19, 2008
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
My power supply keep on blowing fuse. I tried replacing fuse twice and immediately blown when plugin power. What could be the reason?
A dead short is more than likely. Potentially a shorted out compressor or wire pinched or a bad control board. I'd check the compressor terminals to ground, any motors to ground. With and without the wires hooked up to them. If the compressor or fan motors are grounded out it could cause that symptom. If you test them with the wires hooked up it will tell you if the wiring is shorted to ground.
Mar 24, 2016 | Cuisinart Cwc-1600 16-bottle Wine Cellar...
Cuisineart CWC-600 wine cooler no power
Yup you bet, all you need to do is connect a $15 temperature control you can get from any appliance store, fix it to the back of the machine and find a way to ge the probe into the fridge, wire it In series with the compresser and bang you have a working cooler. If you need more info just let me know Good luck
Sep 07, 2012 | Cuisinart Private Reserve CWC-600 Wine...
6 bottle unit model cwc-600 died after 6 months. Acts like it isn't plugged in or a blown fuse. But no fuse!
The fuse is on the circuit board, behind the rear cover. It's a 2.5 ampere metric fuse. These boards are very voltage spike sensitive, and chances are you need a new board, as the rectifier diodes in the switching power supply blow and short out easily. If you get a new board, use a voltage spike power strip to protect it.
Nov 02, 2010 | Cuisinart Private Reserve CWC-600 Wine...
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Cuisinart CWC-1200 Wine Cooler Logo
567 people viewed this question
Top Cuisinart Furniture Experts
Maxumized
Rabbit Brains
Rabbit Brains
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
