Question about Consew 206RB
Jumping a stitch
Every now and then, my machine jumps a stitch. What is causing that.
  • hevans45 Jul 17, 2008
    my 11 yr old consew regularly skips stiches. on 2 layers of naugahyde it will skip abot every 5 inches. can you describe how to adjust needle height and other adjustments?
  • 323 Answers
There are several possibilities.The timing may be off, the hook/needle clearance may be off, the needle bar may need adjusting, the needle may not be inserted correctly, the fabric you are sewing through may have a gummy residue on it which is causing the thread to stick to the needle. I would change the needle first and make sure It is positioned correctly(long grove to the left) and inserted all the way up.
sewman7
Posted on Jul 08, 2008
When I use the long stitch or the basting stitch on my 1230 the thread jumps out of the take up lever after a few stitches. Is there a way round this please? It's fine for normal stitching.
Ive had that happen on other machines. I used tape to close the opening in the top of the takeup lever--no more jumping out. Be sure to ALWAYS RAISE the presser foot when threading the top thread.
Jun 14, 2017 | Sewing Machines
Bobbin keeps jumping out
Hi Anonymous, The link below is a YouTube video showing how to thread a bobbin, The sewing machine is a Singer...Also there's videos down the right side of the link that may help..... CHEERS..
Sewing Basics 1 How to thread your machine
Mar 05, 2016 | Sewing Machines
Check and rethread upper thread message appears often even when the upper thread is not broken
The thread may not be lodging firmly in the tension mechanism. Make sure that the thread is firmly settled between the tension discs.
Also keep an eye on what is happening with the thread in the take-up lever (the arm that moves up and down with each stitch on the head of the machine) as the thread may be 'jumping' out thus causing the message.
What is the make and model of machine with this challenge?
Oct 13, 2014 | Sewing Machines
Check and rethread the upper thread message on display screen appears often even when the machine is threaded
Oct 13, 2014 | Brother InnovIs 4000D Computerized Sewing...
Bobbin jumping
Check your bobbin for burrs, if you find any gently sand with fine grit sand paper.
Oct 25, 2012 | Janome Memory Craft 10000
My machine seems to jump alot and the underneath stitches are just tying itself into lots of knots.
Is it just the bobbin that is jumping? This will happen if you have the bobbin in upside down. Both sides look the same, but you want to make sure the bobbin will turn in the same direction as the little arrow on the metal right by the bobbin slot. If you goof, the bobbin will keep popping up and down and you'll get knots.
Jul 02, 2010 | Janome 1017 Mechanical Sewing Machine
The bobincase springs up giving no stitch in singer inspiration
Try buying a new bobbin case, it probably was damaged by jumping out of position.
May 06, 2010 | Singer 5050 Mechanical Sewing Machine
Jumping stitches.
Replace the needles and choose size according to the thickness/weight of the fabric you are serging.
You may have to re-thread, here is a video from Threadbanger - http://www.allbrands.com/products/abp08027.html
Mar 02, 2010 | Janome MyLock 634D Mechanical Sewing...
My ls2125i won't stitch
Although I am not a expert at sewing machines, I have worked a lot with an industrial sewing machine. You might check the tension of the thread that goes through the needle. If it is to tight it will pull it through the needle. There should be somewhere on your machine that you can adjust the tension.
Jul 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Jul 27, 2009 | Bernina Virtuosa 160
Consew 206RB Logo
116 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
