Question about Kenmore 24032\24036 Top Load Washer
The water level isnt working - Kenmore 24032\24036 Top Load Washer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Here is a video that will explain the "pressure switch" operation to you.
Posted on Dec 31, 2010
Hi, What controls the water level and turns off the cold water shut-off solenoid on an Admiral washer? It sometimes sticks and floods the floor. Thanks
the water level switch (the knob that say low med. extra lg. ect) controls the water level, it probably isnt the trouble, but i suspect that the water valve (where the hoses attach)is sticking open to determine this,when it does flood unplug the machine if it continues to fill while unplugged the valve indeed is sticking
Jul 20, 2011 | Admiral Washing Machines
Engine light on ...message says =engine power reduced.. and now temp is reading hot ,message says check engine temperature ...have had fluid levels checked , they said i had plenty of coolant.....could it...
im going thru the same issue right now, for 1 dont let the needle go more then 3/4 line , you can damage other parts, ive had radiator , water pump, thermostat, coolant level checked and fan replaced but still same ish, ive learned allot dealing with this car , 1 if ur ls starts running hot in traffic or on street , then ur fan isnt working properly, my fan used to work but was loud and was on all the time , fixed that issue , now as i described in traffic she starts to go hot , ur fan is a hydraulic fan which is powered by power steering fluid so since i have a new fan the only problem could be is that my power steering pump isnt working not sending fluid thru fan, 2 if it has to do with the heads i was told to get rid of car, not worth the cost , i hope this wil help a bit and hopefully it isnt the heads
Apr 20, 2011 | 2002 Lincoln LS
My westinghouse washing machine LT809s keeps beeping at me and displaying the error code LL?
It means Low Level. Your water level is too low. Your machine isnt filling up properly or the water is being siphoned out as it fills which means your drain is lower than your water level. or your drain does not have an air lock in it any more.
Mar 31, 2011 | Washing Machines
I have replace the thermastat and water pump and the heat still is not working properly
what anti freeze did you put in it and what level is it at if its low it will do that and if there isnt enough water with antifreeze it wont warm up enough
Dec 05, 2010 | 1995 Lincoln Mark VIII
What is the refrigerant oil capacity for a Saturn Sl1
do you mean the AC or the water coolant ?? if the water coolant then fill to the top as it will find its own level ,if the AC level then i wouldnt know because this vehicle isnt sold here in spain but i would hazard a guess and say about 700grams of R 134 would be far out
Jun 04, 2010 | 1997 Saturn SL
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Water level needs to be adjusted, too low
Check for blockage in the water inlet pipe. As per the manual there is no way to adjust the water level.It is automatically chosen by the machine.
Jan 10, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
WHIRLPOOL DISHWASHER ADP6000IX
your not alone. i to have this error 4 and so do hundreds of others.it means low water level even like mine your water level probably isnt low.what happened to mine was the sensor got a layer of fat and oil scum buildup on it and couldnt detect the water level so i cleaned it and worked good for another month. then same problem.solution- dishwasher had an "accidental short due to water leak" wich insurance covered and bought me a new dishwasher (fisher and pikel) now no more problem
Jul 30, 2008 | Dishwashers
Danby 22in dishwasher isnt getting enough water
There are a few things to check. 1. Do you have enough water pressure in your lines? It may not be filling enough. 2.Is the washer balanced? Try making sure that its on a level surface. 3. Make sure that your hose isnt kinked, and check the back in the screen to make sure it isnt clogged. 4. Is it above the height of its supply? If so, try finding a lower space to put it on. 5. Take a cup or two of vinegar and run it through a cycle. 6. make sure that, in the arm, there is no clogs or food. I'm not 100% sure what the problem is, other then its not pumping water into it at first and sounds like its blocked some where down the line. If you've never cleaned it with vinegar before, I'd imagine that would be the problem. Hope this helps
Sep 20, 2007 | Danby 22 in. DDW396 Free-standing...
Dish washer not filling with water
there can be several reasons: as a start, split the door and check for broken wires in the wiring loom where it passes round the bottom of the door. also check the circulating pump is not burnt out.
May 06, 2007 | Bosch SHU5307UC Built-in Dishwasher
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
