Question about Avanti FF1101W Top Freezer Refrigerator
Hotpoint hts17gbserww My refrigerator section is at 32 degrees, but the freezer is only 18. The single contriol setting is at 4. How do I get the freezer closer to 0 degrees and the fresh food section a few degrees warmer?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
if you have the freezer set to the coldest setting, you may want to check your door gasket.
Try and put your mouth/lips close to the seals, your nose/lips can sense cold very well. if you feel cold coming out, replace the door gasket.
if the door gasket seems ok, you maybe low on freon, or a defective temp sensor. or you may even have a defrost problem.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Testimonial: "Thanks for suggesting a couple of things to check."
How to lower freezer temperature
Not sure what you mean by the freezer too cold? The freezer section should be at or below 0 degrees C or 32 degree F. if its working properly. If the FF section is too warm and your temp control door or vent is at max cold either the vent is not moving (stuck in the closed position) or the fan in the freezer is not working.
Nov 10, 2014 | Frigidaire Refrigerators
What should the temperature be set on for a
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Aug 30, 2014 | Kenmore Refrigerators
Temperature of thermo defrost samsung
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 - 38 degrees F or 1 - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrress C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower. See more at:
http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 01, 2014 | Refrigerators
40 TO 50 DEGREE IN SIDE REG/ FREEZER 32 DEGREE IN FREEZER. HOWEVER CLEANNING RESET DAILS BRING US 10-0 DEGREE FREEZER/ REF 32-38 DEGREE IN REF. THIS REF WILL NOT SABLE ITS SELF. WINTER TIME NO PROBLEM/...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Hotpoint Refrigerators
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
What is the recommended setting for two door refrigerator? The settings are from eight to one in descending order. We have it set on seven and it is not keeping refrigerator cool to say the least.
Should be #4 on single thermostat control and #4 and #4 on dual thermostat control,either will put the fresh food section at 37 degrees and freezer at 0 degrees. Good luck !
Nov 27, 2009 | Televison & Video
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Jun 24, 2009 | LG LRTP1231W Top Freezer Refrigerator
The problem you describe could be caused by a lot of different things. To start with, is the fan in the freezer running?
Dec 30, 2007 | Avanti FF1101W Top Freezer Refrigerator
Avanti FF1101W Top Freezer Refrigerator Logo
222 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
