Question about Philips FW-R7 CD Shelf System
When I put a cd in the recorder drawer it keeps opening after I close it. What should I do ?
My unit has started doing the same thing about 6 months ago (the record cd tray keeps opening again after a new disc is inserted.) My unit is about 10 years old so I figured it might be because I've recorded so many CD's and it's not sensing the disc correctly. I'm stubborn, so every time this happens I press the button to reload the disc and keep doing that until it loads correctly and starts reading/initializing. Sometimes it loads after a couple of opening/closing attempts, sometimes it takes a dozen or so attempts. But eventually it loads. It's frustrating to do this but it's worth it because this is such a good unit. However, most importantly the best possible and correct type of discs must be used. The only ones that have worked consistently for me (very rarely is there a bad disc) are Sony CRM80RS. I use these exclusively now. As of April 2011 they're still available online from Amazon and Walmart, and other sites too. Sold in 30 or 50 packages and fairly inexpensive. I've just read some of the other answers on this site and realize the problem could also be connected to a dirty laser, so I'm going to try wiping the 'eye' very gently with a Q-tip. It might help.
Posted on Apr 07, 2011
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
Dvd drawer opens and closes continually
the inter relay swich on the door is molfushing,or the open and close butten is bad'', try closeing the door and at the same time that the door close's unplug the power and then plug it back in after a few seconds and see what happens it my stay closed and then you can play it,, and it my stop doing that ''if not you will have to take it in to a repare shop'''' my names is ''james ''' let me know if this works for you''' you can e-mail ' me back at '' jay_win2002@yahoo.com .
Jan 30, 2009 | GoVideo VR3845 DVD Recorder/VCR
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
DVD stuck in player SONY RDR-VX 515
Take the lid off by taking the 2 to 4 screws out of the sides of the unit to get the disc out.
Feb 19, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Ilo dvd player
Did you find an answer for this? I have the same issue.
Jan 05, 2008 | iLO DVDR05 DVD Recorder
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Philips FW-R7 CD Shelf System Logo
89 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
