Question about Dishwashers
I just purchased a BRADA EP9242AWW portable dishwasher and after the third load it stopped in the cycle...had a beeping sound to alert me of a problem...shows E1 on the panel and will not drain the remaining water at the bottom of the machine...help PLEASE
SOURCE: brada portable dishwasher
I have a manual if you still need it and I was able to get the adaptor from the Brick when I bought the dishwasher. To be honest the manual doesn't tell you much.
Posted on Dec 22, 2008
SOURCE: pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Posted on Jan 05, 2009
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
tbreeze47
  • 3083 Answers
SOURCE: brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Posted on Mar 14, 2010
SOURCE: Brada dishwasher EF2401 - water in bottom
I just moved in to a new house with brada dishwasher, everytime I used the water leeks from the bottom, can somebody help me to fix it, or do you think I should throw it away and get a new one.
Posted on Aug 08, 2010
Where can I find replacement wheels for a brada portable dishwasher model EP9242AWW?
1. Google: "Brada Dishwasher Parts" and select one of several options
2. Amazon is also advertising appliance repair parts.
Pete
Sep 28, 2015 | Dishwashers
Brada portable dishwasher EP9242AWW
The pump is blocked or not working
Apr 13, 2014 | Frigidaire Dishwashers
Beeping won't stop at end of cycle
Our Bosch does the same thing, we just open the door shut of the power and close the door again so the heat can sanitize the dishes. I don't recall if there is an alert off button though.
Jan 08, 2014 | Bosch SHU9926UC Built-in Dishwasher
Brada EP2402WW/BB dishwasher
Where can I buy parts for my Brada portable dishwasher model number EP2402WW/BB.
Dec 01, 2012 | Dishwashers
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
Brada dishwasher ef2401 wont start wash cycle
Mar 13, 2010 | GE 24 in. Profile PDW7800 Built-in...
BRADA dishwasher looking for manuale and instructions to operate
My Brada dishwasher is not draining and is beeping halfway into the cycle and not finishing. There is water in the bottom.
Sep 13, 2009 | Dishwashers
Sep 05, 2008 | Dishwashers
Dishwashers Logo
960 people viewed this question
Top Dishwashers Experts
Owen Barnes
