Question about Vacuums
I have a Byron TX2 wireless door bell consisting of a push button, a plug-in part and a remote, battery operated part which has stopped working. I have checked the batteries in the remote part also checked the plug-in part and can find no problem. I've also looked in the push button and see that there is a round, lithium battery in it; is it possible that this needs changing and is there an easy way to check it?
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
Chain came off tracks...repaired it and now it will not run full cycle...only goes a foot or so and then stops
if your talking about a garage door opener , pull the manual release , drop the door all the way,, with the handle still disengaged,, push the button to drop the door,, latch the handle,, try that , if that doesn't work, you need to adjust the chain so that reaches the stops at the correct time, here is a video on it,, Good Luck http://www.ehow.com/video_8739813_adjust-chain-garage-door-opener.html
Sep 11, 2011 | Vacuums
When I am playing a DVD and want to stop it over night, what button do I push on the remote?
You can just press the stop button, but make sure you keep the DVD player on overnight. In the morning just hit play and the movie should resume where you left off.
Jul 28, 2011 | Vacuums
I have just purchased a wireless doorbell but it does not explain how to change the tune, please help.
Most wireless Door bells go ding-dong! Does your doorbell play Greensleves, or Home on the Range?
Did you get 2 buttons with it?
One is for the front, which makes the bell chime one way and the other is for the rear and it makes it chime differently.
Jun 29, 2011 | Vacuums
Evo 46400PL Ed3 wireless door chime, no connection between the bell push and the chime unit.
Maybe the batteries are emty, is that not the problem then lay down the bell push in your living room for 1 day, the companents can be a little wet, you can't see that ( they look to be dry) I had this problem too and it works.
Jun 26, 2011 | Vacuums
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
I set up my ONYX SW2300XS which I recieved as a gift (so no reciept) for the first time today. At first it was working well, I inserted a dvd and it played well. I played with the zoom and the skip...
Solution: Return it back!
I had other problems and decided return it.
At first it looks so good: HDMI, SD...inputs and so on.
But operation completly screwd up.
It is a SHAME !
Ed
Nov 16, 2010 | Vacuums
Vacuums Logo
690 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
