Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
The heating element on my Frigidaire FEX831CS0 washer dryer combo burnt out, how much will it cost to repare it
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Here is a link to the part you need. I do believe it comes with instructions for the repair.
Posted on Dec 31, 2010
Why would a frigidaire flse60rgs1 combo dryer runs but not heat and washer not start?
check out house breaker and could be heating element problem or thermostat issues ,not enough info for more respond .
May 18, 2014 | Washing Machines
I have a frigidaire FEX831CS0 that doesnt get hot while drying. Just blows cold air. Im assuming heating element...
Before you reinstall the part, have your ducts and air vents cleaned so it won't burn out again. It only costs around $150.00 but will make a huge difference in your air quality as well as heating and dryer issues.
Mar 05, 2014 | Frigidaire FEX831CS Top Load Stacked...
Electrolux Dryer Heating Element 131553900 is this the right one for model #fex831cs0 or can you restring the original if so what is that part Number
Hi L Martin - For this particular model FEX831CS0, the heating element part number is 131475320. The part may be purchase directly from the manufacturer or through a part distributor in your area.
Mar 18, 2013 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Open ground at dryer outlet
Hi robert_cr334
Go to the following webpage and see that you have the wiring correctly
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 15, 2012 | Frigidaire Dryers
It leaks water after its about half full does it have a hole in the tub?
I doubt if the tub has a hole in it, BUT the increased pressure and weight of the half filled tub could force water past a damaged washer. How did the washer get damaged, probably by the spin bearing starting to fail.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FEX831CS0/1428/0152000/R0310016/00005?blt=06&prst=&shdMod=
Items 21 and 26 are the parts that I would suspect.
Jul 20, 2011 | Frigidaire FEX831CS Top Load Stacked...
I have a frigidaire stackable washer/dryer model number FEx831cs0. The washer is working just find but the dryer for a few weeks has been making the worst screeching sounding in the world. I am not sure if...
A loose belt often makes a squeak that pulsates with the clothes hitting the paddles in the drum. It's probably the upper drum glide or rear bearing. If it's a constant screech coming from the front, it's probably the glide. If the noise seems to be in the back, suspect the bearing. You might check for a sock or something small that is stuck somewhere between the drum and the dryer.
Glide: http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/916658?modelNumber=FEX831CS0
Bearing kit: http://www.repairclinic.com/PartDetail/Drum-Bearing-Kit/1851?modelNumber=FEX831CS0
Neither are very difficult to repair.
Other parts for your machine:
http://www.repairclinic.com/Shop-For-Parts?s=t-%20FEX831CS%20-%3d%3d
Good luck.
Feb 28, 2011 | Frigidaire FEX831CS Top Load Stacked...
The heating element on my Frigidaire FEX831CS0 burnt into three parts. One of the parts dropped to the bottom of the heating element and grounded out. I changed the element but now the dryer won't start....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Nov 19, 2010 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
534 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
