Question about Nokia 6230
Getting to the sim card
How do I open the phone back?
  • widge Jul 16, 2008
    Ha! I did. All solved!!
See an expert
Posted on Jul 10, 2008
Were do i put the sim card i have a nokia 6111
Hello fridge,
i have some tips on how to install sim card on your cellphone:
Install SIM card
1. Make sure that the cover of the connector
panel is closed.
2. Slide the phone open.
3. Open the SIM card compartment (1) on
the back of the slide
4. Slide the metal SIM card holder towards
the compartment lid to release it (2).
5. Open the SIM card holder.
6. Insert the SIM card in the holder as shown (cut corner at
the upper right).
7. Close the SIM card holder, and press it down slightly.
8. To lock the SIM card holder, slide it away from the
compartment lid (1).
9. Close the SIM card compartment (2).
hope this helps :D
Apr 24, 2011 | Nokia 6111 Cellular Phone
How to replace or change Sim Card in i690? How to open up the cellphone to get the Sim card out?
ok if you want to replace the sims card just go to your cell phone company and they will take off the back and in there will be the sims card and battery. I belive that for a new sims card it will cost 15 dollars
May 12, 2010 | Motorola Mobility i760 Cellular Phone
How do I remove the Sim card from a Motorola Razr V3M cell phone?
it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
Good luck to you.
Mar 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Skiphone help
my skiphone was previously owned by someone who owned a 3 sim card.. i own a 3 sim card yet i put my sim card in both simcard slots, but the phone either displayed 'insert sim card' or 'emergency'
is there something i can do get my sim to work in the phone?
Oct 10, 2009 | Cell Phones
How do i get the sim card out of my I phone
open the back of your phone, pull sim card out
Sep 21, 2009 | Apple iPhone 3G
Cant get my sciphone to work
okay turn your phone off take the back off ,battery and take the sim card out now put the battery back in with out sim card .. turn on. now go open sim and close sim 2... turn off...remove back and battery put sim card in slot 1 make sure its in all the way put battery and back on ... turn the phone on... give it a few minutes it should work....
Jun 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Samsung phone
I assume that if you cannot remember your password or pin and have got to this point, then you may not have any other options and will lose any contacts, music, pictures and anything that you had saved on your phone, this will not effect your memory card (If you have one inserted, or your SIM card (Which should NOT be inserted during the reset anyway.)
WARNING!!!!!!!! This will reset your phone back to the factory settings.
( Remove the battery and take the sim card out. Power-up the phone, you will see the insert SIM screen. Type in *2767*3855# like you are making a call, press send.
After you enter the code it will take a few seconds ( you should get text saying not to do anything and that it will reset when its done. ) The phone will automatically restart. Shut the phone back off, then put your SIM card back in and power your phone back on. That's it, your done.)
Remember that it WILL DELETE EVERYTHING off of your phone, so i HIGHLY recommend after the reset and for future purposes that you save everything off of your phone and upload ALL your contacts to your SIM or memory card. to do that:
COPY Phone to SIM:
1. open up the address book
2. options
3. OPTION 13: COPY TO SIM ..or.. OPTION 14: MOVE TO SIM
(NOTE: OPTION 13: COPY TO SIM will produce multiple copies, showing PHONE and SIM contacts (both be displayed in your address book list.) To fix this: you will have to open the address book settings, "View Contacts from" : SIM or Phone.)
COPY Phone to Memory Card:
1. open up "My Stuff"
2. options
3. option 4: copy folder
4. Copy to: Memory Card
Hope this helps.
JD
Oct 28, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Unable to open back of phone to change sim card
The SIM card just slides out - there is no catch or door to unlock.
Aug 11, 2008 | Motorola Mobility W375 Cellular Phone
Nokia 6230 Logo
14 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
