Question about Oreck XL Ultra Bagged Upright Vacuum
Where does the static wire go in the handle. It fell out and now I am having trouble getting it back in. I fixed the cord myself. Model XL2100rh
    Problem Solver:
If you look closely, you can see a sahllow groove along the inside top of the handle. The curved portion of the static wire fits in that. One end fits in a hole just below the switch, the other end just goes down inside the metal post.
Posted on Jan 23, 2011
  • John Golden Nov 18, 2011
    Thanks that worked, wire didn't stay exactly in the groove, but mostly.
Repair manual for an electrolux 1205
That job should be handled by an authorized repair service. Please do not attempt this on your own.
Sep 18, 2016 | Electrolux Vacuums
Top cord handle fell off
The spring is part of the silver power cord clip that you flip around at the top of the handle to release the power cord that has been stored in a coil sour the fixed position plastic hook at the bottom of the handle and this one at the top. There is a long silver screw that goes through a washer then through this clip. The clip is in two parts, the hook or clip that rotates and a saddle that is stationary against the handle. The spring then goes on the screw under the saddle and finally is skewed into the handle.
Mar 16, 2014 | Riccar 8955 Upright Vacuum
My dog chewed the plug completely off my Bissell vacuum, model 61C5-W. Can I fix it myself, and where can I find the replacement cord?
The power cord should be a standard 3 wire cord. Any hardware store. Just buy the length you want. You will have to remove some covers/plastics to get to where the cord connects inside the vacuum. Look for screws holding panels in place. Once inside, you'll see how the cord is attached. Just replace the old with the new. Not critical which of the flat prong wires goes to + and - but be sure the ground wire (usually copper) goes to the ground screw and not a hot connection.
Oct 15, 2013 | Vacuums
Kirby Generation 3: Having trouble putting plate back on where electrical cord attaches. Ever since the shop put a new cord on for me, I have trouble using release lever for dropping the handle when I...
There are 2 tabs on the bottom front edge of the switch plate which slide under the metal top cover. Make sure these tabs have not gotten bent upward so they will not slide under the top cover. If they are bent, simply pry them open. Also, note that the handle pivot has a sliding latch on it to allow the handle to be fully lowered. To lower the handle flat, push the little knob inward.
May 03, 2011 | Vacuums
Eureka Boss 4D (5892BVZ) - Switch Replacement & Fried Wires
If you got the handle apart, Id say you can probably fix it yourself. You might be able to patch it but I would say to maximize your effortrs please visit RepairClinic.com to find the exact replacement parts you need. They also have expert advice and guidance available.
I hope this works for you.
a
Oct 02, 2009 | Vacuums
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 | Vacuums
Brush not working when the handle is reclined
Sonds like you have a problem with the self propel switch in the handle. Since you didn't provide a specific model number, I can only give you generic information on what might be the problem.. Here is a link for a hoover upright model ( may or may not be yours) but it does show the switch in the handle that does sound like your problem... http://www.hoover.com/pdfs/manuals/U6634900.pdf If you can provide a specific model, perhaps I can provide specific details on the repair.. Good Luck !
Sep 12, 2008 | Hoover Vacuums
Hoover Model S3281, disassembly instructions
GET TO THE REEL AS FOLLOWS:
(BEFORE YOU START, BE SURE TO UNPLUG THE DIMENSION FROM THE OUTLET)
1). TURN VACUUM OVER AND USE A FLAT-BLADE SCREWDRIVER TO WEDGE/SLIDE THE WHEELS OFF (PUT THE SCREWDRIVER BLADE BETWEEN THE LITTLE BLACK WHEEL BRACKET PIECE AND THE GREY CHASSIS OF THE VACUUM AND SLIDE/WIGGLE THE WHEELS OFF);
2). THE 2 DEEP HOLES AT THE TOP OF EACH WHEEL RECESS LEAD TO 1-1/2" LONG PHILLIPS SCREWS >> UNSCREW THEM;
3). AFTER REMOVING ALL 4 SCREWS, YOU SHOULD BE ABLE TO EASILY LIFT OFF THE TOP OF THE REEL/MOTOR COMPARTMENT.
4). CAREFULLY LIFT AND ROTATE THE CONTROL PANEL TO THE SIDE.
5). THE REEL IS NOW IN PLAIN SIGHT.
6). I’M STILL TRYING TO FIGURE-OUT HOW TO SAFELY ACCESS THE GUTS OF THE REEL MYSELF. I HAVE A PROBLEM WITH INTERMITTENT VACUUM POWER AND ALSO WITH WEAK CORD RETRACTION.
ANYWAY, GOOD LUCK TO YOU !!!
Jan 01, 2008 | Vacuums
Oreck XL Ultra Bagged Upright Vacuum Logo
433 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
