Question about Remote Starter with Keyless Entry
Where is the easiest way to get to a tack wire in a Ford Escape 2004
  • 15,935 Answers
TACH Any wire that is NOT WHITE/PURPLE or RED @ IGNITION COIL or FUEL INJECTOR
Posted on Jan 02, 2011
2004 ford escape cylinder 6 miss fire change plugs. wires ,coil, injector,its get no signal to coil for fireing
I suspect the PCM has a bad driver from the misfire. Need a PCM. Get numbers off PCM and find on ebay cheap.
Just one cyl misfire DTC code?
Jun 29, 2011 | 2004 Ford Escape
How do I dis-assemble the driver side outside mirror on a 2004 Ford Escape? I have a new one to install.
you have to remove the panel on the inside to access the bolts that hold it on also will have a wire to disconnect
Nov 14, 2010 | 2004 Ford Escape
How do you remove an alternator from a 2004 v6 ford escape?
Release the tension on the belt, remove the wiring on back of alternator and remove the bolts. Installation is reverse of removal.
Jul 06, 2010 | 2004 Ford Escape
2004 ford escape wiring diagram
This is for 2005 Escape, its possible that can helpfull... LINK
Hope this help.
May 15, 2010 | 2001 Ford Escape
My son in law is going to install a class 3 hitch on my daughters 2005 ford escape. From what we can see, the only wiring harness comes from the front down the passenger side. There is no quick connect...
auto stores have wiring adaptors for all cars.  And that is the easiest.
Also if you are going to do some serious towing have a oil cooler for the motor and transmission installed.   U-Haul does thjese
Mar 26, 2009 | 2005 Ford Escape
Tachometer doesnt work on my 86 ford escort.how do i fix this problem?
if the car has a distributor ignition system, the tack wire comes from the distributor plug, not sure what color the wire is, the tack gets it's reading from one of these wires. check wire from back of tack. trace to distributor and check connections. if connected, tack is probably bad.
Jan 26, 2009 | 1991 Ford Escort
2004 Ford Escape Electrical problem
Wen you put back the battery on i think that you mist a groud wire that was on your groud cable or a power wire +try this and good luck
Apr 15, 2017 | 2004 Ford Escape
Remote Starter with Keyless Entry Logo
19 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
