Question about Pelonis HF-0019 OSCILLATING HEATER - OFF WHITE
Why the heater wouldn't come back on after it was turned off.
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
AC/Heater Blower Fan in 1990 LS400 works intermittently
Due to the age of your vehicle, the brushes in the fan motor are worn out. you will have to replace the fan motor, it is not serviceable.
May 30, 2017 | 2001 Lexus RX 300
I have a 2000 Chevy Venture van and the heat when turned on blows cold. For a while it was still blowing out warm air thru the back vents but now it is all cold. The van wouldn't warm up at all e
needs the water system back flushing out, heater being cold is its blocked up some time a few back flushes and forward flushes with a hose pipe should free up the dirt inside, same with the engine and radiator. there are meany videos on you tube to help you understand how to back flush you engie. but do the radiator and engine and heater separate so the muck does not go back into the engine.
Aug 16, 2017 | 2003 Chevrolet Venture Passanger
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Brand new versa 130 propane .Was working fine but then it was unplugged while running.Plugged it back in and it wouldn't work.Found out it was out of propane.Had the propane tank filled.Now the...
I would contact Raypak technical service and they may be able to help you correct the issue over the phone. This is even more likely since the heater is new. I hope this helps.
Aug 12, 2011 | Raypak 130,000 BTU Propane Gas Pool...
We have an estate by whirlpool dryer that quit working. During last cycle it made a loud bang noise that ended the dry cycle and the clothes inside were dry. When we tried to restart it, it wouldn't...
The fuse is tied into the door switch circuit and looks like this:
Unplug the dryer and remove the rear cover. All the heater components is back there.
Service manual and more info are HERE at my FixYa tip.
Jul 17, 2011 | Estate TEDX640JQ Electric Dryer
They worked on our city water and now i'm getting no hot water... before that it worked but i don't think to capacity.. it wouldn't fill the tub before getting cold.... it is a rheem 50...
As long as the water heater is not leaking or not big enough that would be the only reason to replace heater. If you are running out of hot water or it's cold, check the power source first to make sure you have power to heater. Then check the reset button on the top thermostat and make sure it's not tripped if it is it wil not heat. If so press red button aloow it a little time check for hot water.
Next step woul dbe to turn power off and drain water to replace both elements out. Once changed out turn water back on and open a faucet to remove air out of the wtare lines. Once you get water flowing out of water lines now you are ready to turn power back on. allow about 30 to 40 monutes and you should have hot water.
Jul 09, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Pelonis HF-0019 OSCILLATING HEATER - OFF WHITE Logo
Top Pelonis Heating & Cooling Experts
paulcarew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
