I have a Grundig video player, about five years old. The remote control has suddenly ceased working although I have changed the batteries. The only information I can give you is that it's a Grundig VHS HQ recorder with GV 9110 on the front. The number on the remote is 076NOEDO8A. Is it possible to get a replacement or for you to suggest what might solve this problem. I don't want to buy a remote that serves "all makes" because my experience is that it doesn't! Thank you.
5 Suggested Answers
  • 6 Answers
SOURCE: remote no longer controlls recorder
Remote can be used to control more than 1 recorder, on the remote press enter and 1 simultaneously, this should switch the remote to control dvd 1.
Posted on Oct 27, 2007
SOURCE: RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Posted on Jan 06, 2009
welcomejee
  • 10594 Answers
SOURCE: download a manual
Dwonload required manual from HERE.
  • 362 Answers
SOURCE: No remote, front buttons don't work... how to change channels??
Hold down the MENU button on the control panel for more than 8 seconds to unlock buttons.
Lone99star
Posted on Jun 05, 2009
Testimonial: "Thank you! It worked!"
  • 864 Answers
SOURCE: Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Posted on Jun 30, 2009
How do I get my LG AKB73375501 to interface with my Blu Ray player?
It has to be setup with blu-ray by setup codes. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 30, 2013 | LG ELECTRONICS Remote Control AKB73375501...
Remote for grundig glcd1906hdvw stopped working. Tried all the suggested "fixes".
It will be best to buy one universal remote control to setup with the TV, rather than trying to repair the present remote control. Setup code list to remote control will be there along with the packing. If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given. Check them and determine which remote control should be selected for your TV.
Mar 09, 2013 | Televison & Video
Sony RMT-D187A stopped working!
1= change the batteries by new ones
2= clean the contacts cleaners with contacts cleaner
3= resolder the wires contacts batteries
4= retight the spring contacts batteries with pliers for better contacts
5= open the r.control clean the kepayds switch for dirty, oxide, and test for open, bad contacts.
6= try agan, if doesnot work go to the repair shop TV for fix it.
God bless you
Jul 19, 2012 | Sony Televison & Video
How cfan I obtain user guide for Grundig SCD88 player
These models are out of production and also redundant. It is possible that the battery also had gone weak if the set does not power on, otherwise all what is needed is to get in touch with the nearest Grundig support center.
http://www.grundig.co.uk/Audio.html
Dec 12, 2011 | Grundig Audio Players & Recorders
Got a RCA Guideplus gemstar iniversal remote for an RCA analog TV that is at least 10 years old. Remote has ceased to work despite changed batteries. I'm wondering if it has met its destiny or if it can be...
check to make sure the ifrared lenses are cleaned on both tv and controller, if smuged or dirty, it will impede the rays from making contact. or could be one or both of the lenses have ceased to work, outside that, there is only replacement or repair..sorry..
Oct 17, 2010 | Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Dead remote
try rebooting the remote control by removing the batteries, then press every button one time, replace the batteries with a fresh set and give it a try. If the remote still fails to work contact remotes.com for
Nov 24, 2008 | Televison & Video
Grundig Super Colour TV Serie F 3016 - lack of responce from remote control.
Tell me if there is a battery within this TV set which will require replacement to solve this problem
no there is no battary in tv.
The set works OK otherwise using its own control panel to change channels and its on/off switch to turn it on and off.
your statements itself says that there is no problem in tv.
in my opinion problem is in  remote only.
please try
www.remotes.com
for further help in remote.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
