Question about RCA HDLP50W151 50" Rear Projection HDTV
Hi the picture that is being projected is upside down. How can I make it the right way up? Thanks Liz Womersley
  • 979 Answers
Was it ever right side up?
Posted on Jul 28, 2008
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
We have inherited a Sanyo Pro-X multiverse projector without an instruction manual. The projector was fixed to a ceiling but we would like to use it freestanding. When attempting to use the projector this...
You need to turn off the ceiling mode to get the picture to project correctly. This is in the Settings Menu. See page 37 of the manual which is currently available here: http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcsw30_im.pdf .
Press Menu. Then use the left/right arrows to move to the icon with the projector and screen shown. (Note: right now this row will be on the bottom of your screen and the icon will be to the left side of the row.) Press the down arrow and move to the Ceiling icon with the R. It should be the seventh icon from the upside down "Up" arrow; it's next to the Capture icon with a camera. (Normally, ceiling icon shows as an upside down R when your image is projected right-side up. There is also a rear-projector icon with a mirror image R when the image is right-side up.) Press Select and then use the arrow keys to choose the On/Off options. You may need to press Select again to save the setting.
I hope this helps.
Oct 11, 2017 | Sanyo PLC-SW30 Multimedia Projector
Flex Cable replaced-but now VF is dead, plus...
Hi, I have just repaired my camera following the excellent series of pictures provided by airshod, and I think the viewfinder problem could arise from replacing the tiny board under the D panel covering the lcd panel hinge. This panel has a tiny switch activated by a little projection on the lcd/hinge moulding and on reassembly it is necessary for the panel to be open and at right angles to the body so that the projection is on the right side of the switch for correct operation. I assume that it is this switch which activates the changeover from lcd to VF. It could be that if the lcd panel were closed while asembling the D panel the switch could have been damaged while opening it later, but the board would be easy to replace - the supplier of the cable should be able to obtain a replacement. I'm not sure about the upside picture problem though, it may be related to this but without a service manuel it's hard to say! Good luck!
Aug 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Upside down projection
Hi career link
If you enter the User Menu on the Projector you will see a subfolder that will read Mirror or Flip Image.
Scroll down to this folder and press left or right until the image is flat fronted ( table front projection )
Thanks for using Fixya !
May 21, 2008 | Sanyo PLC XW20A Multimedia Projector
Menu
Hi paulveldt
Very easy ! Simply go into the menu and look for the subfolder that will either read Mirror or Flip Image. Scroll down to it and press left or right until the image is back to normal.
A mountable Projector can project flat fronted ( on a table ) upside down ( on the ceiling ) rear ( from behind - on a rear projection screen ) and upside down from behind ( from the ceiling onto a rear projection screen )
This should do the trick !
Apr 30, 2008 | NEC VT676 Multimedia Projector
RCA HDLP50W151 50" Rear Projection HDTV Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
