Question about Western Digital Caviar SE WD800JD SATA Hard Drive
Dear sir I have WDC WD800JD 80 gb hard drive and I located some bad sectors in 2 partitions, please tell me how to isolate the bad sectors and if there is any way to recover the lost sectors. thanks and best regards
  • Western Digital Master
  • 27,725 Answers
You could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and attempt to repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Posted on Dec 31, 2010
It dousnt show in windows at all
test all leads from "motherboard to hard drive" include electrical extensions if its an ide with flat ribbon 40 pin type make sure its securely seated at both ends this will be the first to fail
hope this helps
Jul 08, 2011 | Western Digital WD800JD (wdc-wd800jd) 80...
My computer didnt recognize my hard disk
Looks like the controller on the Hard disk has malfunctioned. I am afraid, that the Hard disk has to be sent to an expert nearby for Data Recovery. They would have tools which could be used for getting your data intact. But again it all depends on the level of damage to the Hard disk.You may get all / some of your data ot you may get none. Please consult your hardware vendor for this
Apr 13, 2009 | Western Digital Caviar 40 GB Hard Drive
Bad sectors removal and formating Seagate 80 GB
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Sep 02, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Total size is not 80 GB IDE Hard Drive
Two possible solutions but both calls for another software/utility.
1. Use FDISK but you should be booting and running in DOS mode;
2. the other is Partition Magic which runs under Windows environment.
The idea is to delete the existing partition (that shows only 31.50Gb) and thereafter re-partition to the full capacity of the drive. of course doing so would erase the contents. Further, a format after the re-partition is required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 19, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Bad sector affecting partition resize
You don't. Replace the hard drive if you value your information.
Apr 30, 2008 | Seagate Barracuda (ST380215A) 80 GB IDE...
Partitioning my book
Hi daneric,
The Western Digital website has a knowledge base article that describes this process for both Windows 2000/XP systems and Windows Vista systems.
Check the link below for full details on this process. (Please note that this can also be located by searching for answer ID "207" at http://support.wdc.com.)
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=207&p_created=1008908212&p_sid=r_lOYU1j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MiwyJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1zZWFyY2hfZm5sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9MjA3&p_li=&p_
I hope this helps!
The MoDev Kid
Nov 04, 2007 | Western Digital My Book Essential Edition...
Hardisk pro
You cannot recover bad sectors. Your disc is damaged and the drive has removed the bad sectors from being writable. You need to replace your hard drive asap before it breaks entirely. You're going to lose all your remaining data on the disc if you do not back it up immediately. Good luck, Peter
Aug 06, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Hdd
The drive may be damaged physically and is setting the remaining portions of the disc as bad sectors. If this is the case you need to replace your hard drive immediately. If the space is unpartitioned you can do this through windows using a program called partition magic. You can also reformat the drive using a windows cd and it can reformat the drive to 80 gigs (assuming the disc does not have bad sectors).
Aug 06, 2007 | Samsung (SP0822N) 80 GB Hard Drive
Western Digital Caviar SE WD800JD SATA Hard Drive Logo
292 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
