Question about Car Audio & Video
I am trying to locate a manual for a CDC40 Opera Radio fitted in my 2006 Vauxhall Vectra car. My local dealer says that Vauxhalls have stopped producing them.
SOURCE: i had my battery changed
yes you will need to decode the stereo should have four numbers try in the literature you have for the car poeple write this in the strangest places if not can be decoded usually advertised in e bay motors approx £10.00
Posted on Mar 19, 2009
caroldon
  • 17129 Answers
SOURCE: I own a Vauxhall Vectra
Possible that the garage had disconnected the battery terminals and so the radio has reset. You will need to check with the Vauxhall agency /dealership for the said codes or check up on your service book for the codes -- it will be normally written on your book. If not check the data base of the car in your dealership.
Posted on Mar 16, 2011
SOURCE: Free unlock code for my
Hi I have just bought a car and it is in safe mode the car is a vauxhall vectra and the stereo is a delco electronic cdr 500 and serial no on it is gm0500t9120228 pls can you help me thanks Brian
Posted on Apr 21, 2011
  • 4848 Answers
SOURCE: I have just bought a
Press ON and AS together...and leave SWITCHED ON..UNDISTURBED for as long as it takes to automatically reset itself.
This may take up to 11 hours as it depends on how many wrong codes have been entered previously (The waiting time doubles after each wrong code)
Posted on Jun 08, 2011
tinualbinale
  • 436 Answers
SOURCE: 2002 VAUXHALL VECTRA 2200 CC
You can download the free manual for your Vauxhall Vectra by a click on the following link.(http://vectra-c.swi.hu/VectraManual.pdf ).Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Posted on Jun 18, 2011
Hi, Vauxhall Vectra 53 Plate 1800 SXi - alarm sounds without apparent reason, usually in the early hours ?? What may be the fault please ? Thank you
it can be a faulty battery in the alarm unit. when the battery is not charging for whatever reason it send a trigger and the alarm will set off. has been a problem on some vauxhalls over the years. would have it checked out as it can get worse.
Nov 27, 2016 | Vauxhall Cars & Trucks
My vauxhall vectra 2005 won't go into gear when stuck in heavy traffic
Hello Vince Libby,
Several decades now we have not enjoyed seeing Vauxhalls here in the USA ... (wow... nothing (could not even rule-out and AUTOMATIC TRANNY)...
If so = FLUID Level... (also means poor maintenance).
((always keep automatic fluid clean... EVERYTHING lasts longer)).
Else (manual tranny)
But I can give you my EXPERIENCED opinion on your
COMBINATION of SYMPTOMS...
Well... I thought I could
Suffice to say I was going after your clutch slave
... If you've been experiencing any oil loss or spots...
You are most likely not fully engaging your clutch...
Sadly eBay (UK) was the only site that gave me a CLUE
what your "CLUTCH SLAVE" even looks like...
If you are losing any oil (or don't know (check there first).
Hope this helps
vauxhall vectra 2005 slave
Jul 24, 2016 | Vauxhall Cars & Trucks
I have lost my code for my vauxhall vectra ccr 2006 radio it is in safe mode
You need to ring the vauxhall dealer with your VIN number
Aug 20, 2011 | Car Audio & Video
Do you have the radio code for the vauxhall vectra 2.0m 16V
All radio codes for vauxhall standard units are displayed on the car pass , which you should have with your car as it also has the vehicles engine codes as well as key number. if you have lost or misplaced yours then you can ontain a new pass from your local vauxhall dealership, Cost is normally £25. Alternativley you can try to get the unit decoded for around the same kind of money from your local car audio shop, if you don't fancy that you could always upgrade to an aftermarket unit.
Aug 10, 2011 | Car Audio & Video
Lost radio code for vauxhall vectra radio vdo cdr2005
Unfortunately the majority of SIEMENS/VDO codes (including your CDR2005) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
May 12, 2010 | Car Audio & Video
Code for car radio vauxhall vectra radio cdr 2005 vdo
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unfortunately the majority of SIEMENS/VDO codes (including your CDR2005) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
May 01, 2010 | Car Audio & Video
How do i remove a stereo from a vauxhall vectra model cdr 2005
never done one before but if like all other vauxhalls there is 4 grub screws. you need allen key to take out. New vauxhall has wider pin holes than old type so you'll need to cut wire coat hanger into to U shaped bits insert into each side from were you removed the grub screws. slighlty push the wire away from each other and try and grab a slot or something on the face of the radio to pull out. When you have done this look into the cage of the radio and in the back there should be a screw or bolt normally 8mm to remove. Cage should come out then. Disconect plugs from cage and ready fro new radio.
Apr 30, 2009 | Car Audio & Video
Car Audio & Video Logo
427 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
