Question about Echo Garden
Echo 330t chainsaw. This saw seems to be little used judging by the lack of scuffing on the bottom/ground side. It, like all the rest, ran great till it quit. What is there about small diaphram carbs that a kit properly installed won't fix? Do small passages get clogged with no way to clear them? I have rarely pulled a welch plug and found trash there. There is no wear on the butterfly shaft. I put the saw into the shop after my efforts failed, they failed too. Could there be something exotic like crankshaft seal problem? What is the test for seals? The rubber seal at the carb/cylinder seems ok, but can't tell if it's a boot that may have a leak. Carburators are the bane of my 63 years of life. Where can I get a proper education about Zamas, Walbros, etc.? What is the coffin nail that says I need a new carb?
2 Suggested Answers
  • 83 Answers
SOURCE: 46 cc Sears/Poulan chainsaw will not start
Four things I can think of:
1) There is a short in your spark plug wire. When you bend it to connect the plug in the machine it allows the exposed cable to contact the engine block. Examine the wire all the way to the coil.
2) Flywheel key is sheared ( you obviously know how to take off the flywheel since you checked the seals).
3) Flywheel air gap is not set correctly. Loosen the coil. Put the cover of a notebook or the cardboard piece of a cigarette pack between the magnetic portion of the flywheel and the coil. Tighten the coil down. This will get you the proper gap.
4) Your cylinder/piston or rings are scrubbed out. Even though it passed a compression test, on rare occasions it will loose compression only when it fires. So do the following:
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
First if you can get a inline spark tester so you can see if your getting spark with the plug installed.
Posted on Mar 31, 2009
Echo chainsaw ran fine a few weeks ago. Today it won't turn over. The recoil is fine. The flywheel won't turn.
Pull the spark plug out of the saw and put a little cutting oil in the cylinder and try to turn it over.
Dec 08, 2016 | Echo Garden
Where does the small hose on the carb go on the engine
f5f24c66-131d-46da-af84-447310da2d0c.pngConnects to the plug hole immediately to the right of the carb.
Oct 16, 2014 | Echo Chain Saw. 14 in. 32.6 cc Gas Chain...
I used fuel from old chainsaws sitting in garage and used it on my Echo CS-330T. I barley got it and it was basically new with a few hours of use. I guess the fuel was old and the gas was probably not...
Use echo 2 stroke oil Do not use ethanol fuel, use a premium fuel and mix with the oil. Empty all the old fuel out of the saw, Fill with fresh fuel. Should solve the problem
Oct 05, 2013 | Garden
Will not run
You need to make sure it is mechanicaly ok ( not scuffed the piston ) remove the muffler and check the condition of the piston skirt through the open exhaust port, any sign of damage and the machine will need to come apart.
May 08, 2013 | Echo Garden
Why can'tmy dealer parts for my echo chain saw?
have someone else you know call with the model number like they want =to buy one then see if its back ordered or they are stroking you also see if sears parts on line has one they don't like warr repairs they have to wait for there money and can't charge what ever they want
Mar 22, 2012 | Garden
Can't pull the starter cord, it's very hard to do. Removed spark plug and then the pull cord worked fine. Put the spark plug bvack in and once again the starter pull cord was hard to pull. Seems...
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
May 15, 2011 | Echo CS400 18" Chain Saw
How to take out the piston in my chain saw
The cylinder must be removed from the crankcase (be sure to clean the exterior of the engine and all parts with compressed air first). That involves removing the carburetor, muffler, cylinder head, and possibly the entire outer case parts. If the piston/ring(s) requires replacement due to scuffing, the cylinder will likely need to be replaced also. Many modern engines use a chrome plated lining for the cylinder interior and any piston damage will affect the cylinder plating also. Use great care when installing the new piston in the cylinder as the ring(s) are quite fragile. Also look for direction marks on the piston as some engines use an offset pin. Be sure to lubricate everything as you go with saw oil to prevent start-up damage. Hope this helps!
Jun 26, 2010 | Echo CS400 18" Chain Saw
ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 and...
Need size of guide bar nut on model cs-330t
I went here, typed CS-330T in the search bar and found 6 IPLs. None of them list or display bar nuts. Odd!
I suggest you take your saw into your local NAPA Auto Parts store. You might also contact Echo and suggest they add bar nuts to their IPLs for the benefit of the next guy. HTH
Feb 10, 2010 | Echo Garden
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 and...
Open Questions:
Garden Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Are you an Echo Garden Expert? Answer questions, earn points and help others
