Question about JVC AM FM CD DET FACE CAR STEREO
I have a jvc kds-16 receiver. It has been working for about 5 months with no issues. Now there is power to the head unit but I have no sound. I have checked all of the connections, nothing is loose, the ground is good, and I have tried the reset button. still no sound.
    Problem Solver:
  • 8 Answers
What you should try is this. see if you have 12 volts to the yellow wire. the yellow wire controls memory and things like that. it should have 12 volts constantly. also look under the plug on the back of the radio, make sure it is not blown. it acts like the fuse on a power amp. if the fuse on the side of the power amp is blown, the amp will still power up but the fuse is not letting power to the power relays inside to kick the sound outputs on.
Posted on Jun 22, 2013
    Scholar:
  • 127 Answers
Buy a digital volt meter and start checking fuses for the radio at fuse panel . if blow replace it . if not blown remove radio from dash check to see if radio is still grounded . if still grounded take the volt meter turn on to dc volts and take black test lead touch to your radios ground the touch the red test lead to the red with to see if you get 12 volt with car on if not need to find out why .. take to professsinal ..
you can also check the yellow wire on radio it should have 12 volts allways doesnt matter if car in off or running this saves memory for clock and station presets.
if every thing is test out right then you need to buy new radio ..
if you dont feel good about doing this yourself find a mecp car audio installer and have them troubleshoot your problem maybe expensive but a good tech could find out problem with in the first 30 to 45 minutes it get 35.00 per hour to troubleshoot car audio system ...
http://www.tintingbyfredjohnson.com
Posted on Dec 31, 2010
How to set time on jvc kds 16
Call the help desk at crutchfield, they can help.
Sep 09, 2013 | JVC AM FM CD DET FACE CAR STEREO
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
JVC KD-AVX 40 compatiable USB H/Drive
You can use any non powered USB drive (gains its power from usb only). You just have to plug it into your PC and select Properties > Format then make sure you format it in FAT12, 16 or most commonly (recommended) FAT32 file system.
Once you've done this you can transfer all your music onto it then plug it into the USB port lead from the back of the head unit
Feb 26, 2009 | JVC KDAVX44 Car DVD Player
JVC drains battery when OFF, puzzling
The problem is actually the wiring. Check the installation manual, I guarantee the "pro" installer took a shortcut.
There are two power wires (yellow & red +) and a ground wire (black -).
Now, black goes to chassis grounding point. Easy.
Yellow goes to a live terminal in the fuse block for constant 12V.
This retains the settings and clock etc.
Red goes to an ACCESSORY terminal in the fuse block (so key must be turned to at least ACC to allow it to be switched on).
But in the case of my car, the idiot who installed it ran the red wire directly to the + battery terminal. That's wrong, and will drain the battery.
Google for an installation manual, I'm certain your JVC head units will be the same procedure.
Jan 12, 2009 | JVC KD-HDR1 CD Player
Jvc kds 24 car stereo
i have the same model and yes our radio doesnt support the bluetooth feature they did exactly as you assumed they used the same face for the model that supports that bluetooth feature.it is not even bluetooth capable which is unfortunate...if your wanting a radio/head unit what ever you want to call it i useful tip is to make sure it has the bluetooth written on the face such as this....
http://www.crutchfield.com/App/Product/Item/Photos/Default.aspx?i=158MEXBT27&g=300
keep in mind thats not always the case but in most cases it means it has built in bluetooth...but it might just mean it is "BLUETOOTH CAPABLE" meaning you can buy an adapter to make it work. just be sure to ask if it has built in blutooth. most higher end models have built in bluetooth.
Dec 11, 2008 | Car Audio & Video
JVC Car Stereo
The head unit should have two separate +12V connections: One that goes to a switched 12V power that is switched on/off via the ignition and one that is always energized at +12V. If the head unit's switched +12V lead is not connected, the unit will not turn on (except for when +12V is first applied to the "always on" lead, in which case it will immediately eject the CD). Please respond if this is not the issue. Hope this helps!
Mar 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Kenwood KDS-P900
Probably a wiring error. If the processor was faulty, it would do nothing.
Aug 09, 2017 | Kenwood : KDS-P900 GPS Receiver
How do i set a jvc kds-32 radio clock
You'll find your answer here:
http://books.jvcservice.com/booklist.asp?Model=kds-32
Just download the pdf instruction manual.
Jan 08, 2008 | JVC Car Dual SIRIUS Satellite Radio/CD...
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
JVC AM FM CD DET FACE CAR STEREO Logo
231 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
