Question about BenQ FP92W LCD Monitor
Power not on, power button blinks green power light, doesn't power up. Benq FP92W
  • BenQ Master
  • 6,771 Answers
It sounds like you have a power supply problem and the safety shutdown has kicked in, the system will need to be checked by a computer tech with an estimate in mind.
Posted on Dec 31, 2010
Power supply range
RTM
get the operators manual, free online (google is your friend?)
and read it.
its all there.
do you mean what is , the A/C line voltage ranges?
most say so, on the back, did you look there>?
Sep 30, 2013 | BenQ FP92W LCD Monitor
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
Cannon i865. Operator Error message and blinking orange light (5 blinks). Switching off power does not reset. Also used reset technique from this site, this does not seem to work. Any more ideas?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | Canon Office Equipment & Supplies
When I turn desktop on & monitor on, sceen display for about 10sec then monitor go's off. Have put another monitor on desktop and it works fine. Something wrong with LCD monitor
This tends to be a power issue and monitor is hopefully under warranty and will need to be sent back. Otherwise it is pretty much done.
Feb 22, 2011 | BenQ FP92W LCD Monitor
Power button blinking green
trying to start up. if it doesn't light, it's either the colorwheel or the ballast.
Oct 13, 2009 | BenQ MP511 Projector
Benq 24" wont comes back after sleep mode
Try to install the OS once again.
If it turn up the same again then it may be the logical board problem.
Apr 12, 2008 | BenQ FP92W LCD Monitor
Mitsubishi xl2u projector
also have the same problem
Jan 29, 2008 | RIM BlackBerry Pearl 8100
Screen working and after 2 sec screen black
On your power board you will have a faulty surface mount fet with 8 legs that controls the backlights.
There are 4 of these, but if any of them fail the protection circuit turns them all off.
Best best is to get it to a local technician for repair. It is not an easy task unless you have the right equipment.
Hope that helps. =)
Dec 14, 2007 | BenQ FP92W LCD Monitor
BenQ FP767 17" Power but no display?
Different faults here.
First fault is no power, it is bad capacitors on the power board.
Second & third faults are the inverters. (power but no image visible, but feint if you shine a light into the screen)
Check the 4 transistors on the main power board for shorts.
If you are unsure what that means, then take it to your local TV technician, he should be able to solve it fairly cheaply.
Hope that helps.
Oct 11, 2006 | BenQ FP767 17" LCD Monitor
BenQ FP92W LCD Monitor Logo
313 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
