I have taken my Compaq sr1500nx out of mothballs and it boots normally but after showing the Windows XP the screen it displays a white box that says "input signal out of range change settings to 1280X1024 -60hz. I can enter setup (F1). I have tried System restore displays the same thing. The PC continues to run but there is no display on the screen.I don't know a lot about setup (nothing) so I didn't mess with it.
  • djm5657 Dec 31, 2010
    This user seems to know the correct answers to all my postings. Very thorough for newbies like me. Thank you!
  • 4,737 Answers
If you cannot change the display settings in the Normal mode, then your only choice is to get it done from the Safe Mode. Once you press the power button to turn it On, look on the screen and tap the F8 key few times until you see the Advanced Boot Options menu. It should look like this:
Windows XP Advanced Boot Options Menu
Highlight the "Safe Mode" using the up-down arrow keys on the keyboard and press "Enter", wait for few seconds (or maybe minute depending on the configuration of the system and programs installed on your computer), again after you enter your password, you'll see another message similar to this:
Windows XP Safe Mode warning message:
Click "Yes" to proceed. Once the system is loaded, right-click on an empty space on the Desktop and select "Properties", again you'll see another window (shown below):
Click the "Settings" tab and then click "Advanced" button. A new window will open up,
click "Monitor" tab and then select "60 Hertz", click "Ok". Now on the first window, change the resolution settings by draggin the sI have taken my Compaq - nonontech_187.jpgbr />
and set it to "1280 by 1024", if this isn't possible, set it to the lower resolution. Click "Apply" and then "Ok", and restart your computer. Now let the computer boot up normally and change the settings if there's problem in the same way you've done in the Safe Mode. (this time you'll be able to change the settings),
If you have problem, let me know.
Good Luck.
Thanks for using FixYa.
Posted on Dec 31, 2010
My Compaq Presario fall down and its screen gone colourless its not show anything normal when boot windows 7 it's colour goes red colour after booting showing very low quality colour....what I
Check the GPU and motherboard are OK by plugging an external monitor into the VGA socket and then booting. If the external screen is OK, replace the LCD screen.
Oct 09, 2014 | Computers & Internet
How do i find out witch display driver to disable so i can install new video card
You don't need to disable any driver, unplug, use ESD protection, install Graphics Card, move the monitor cable to the new card,(you may have to boot on the old monitor connection and install driver), install the driver for the new card and reboot plug into the new card. Do your windows updates to obtain the latest driver. You can open the Device Manager, open Display adapters and disable the Intel graphics adapter. Is it a PCI or AGP Graphics Card? Remember: with a Aftermarket Graphics Card it requires more Power/Watts, you should consider a PSU upgrade. You didn't post the Make, Model Graphics Card, usually there is a Min. Power Spec. for the card listed on the box.
Apr 10, 2013 | HP Compaq Presario SR1500NX (PX786AA) PC...
Compaq sr1500nx reads NTLDR is missing
boot from your install disk and open CMD, from there use /bootsectit will give you your options
May 03, 2012 | HP Compaq Compaq SR5502FH-E Presario...
Compaq SR1500NX hangs when booting on the "Compaq" logo on the screen. No POST, no ability to enter bios setup or safe mode. I substituted a known good power supply - same symptom. Also reseated DIMM...
Hopefully you didn't snag a BIOS virus (normally loaded on when doing a BIOS upgrade and that file having been pre-infected), but not really a common problem.
The most tedious way to get this figured out is to take every item imaginable off of the motherboard and one by one start replacing all the peripherals. Before anything I would clear the cmos (usually take the silver button cell battery out for about 10 minutes and put it back in) as "the" first step.
Then without even thinking about going into the bios, just start trying to get the computer to POST past the initial logo screen. More times than not, clearing the cmos puts the computer back to a default setting that will at least get you up and running.
Barring that the keyboard isn't the singular culprit to your woes, you should get back to a windows start screen (NOT necessarily getting into your windows desktop). If you get that far, then you have jumped the first hurdle. Reboot your machine and go into your bios, do nothing other than reset your time and date as this will (sometime) cause windows to balk at loading because its own time stamp doesn't match what the bios is reporting, thus it thinks you have relocated the drive to a new computer (how dare we re-use software on a computer we own).
Once that is done, you 'should' be able to get back into windows and make changes that you need, not to mention getting the rest of your peripherals up and running.
Hope this helped...
Oct 25, 2010 | HP Compaq Presario SR1500NX (PX786AA) PC...
On startup, I am seeing the display go blank/inactive just after the xp splashscreen shows up. the system is still active, but no display. tried boot to disc. tried xp repair reinstall. What else could...
This bad video drivers.
Restart the machine and repeatedly tap the F8 key. When you see the advanced boot menu appear choose safe mode.
You will see white text on screen that will stop on a system 32 driver, wait a minute and let it boot through.
Next, go do device manager and uninstall the display drivers.
Reboot the machine and it should boot into windows normally. You may have to reinstall the display drivers if they don't reinstall themselves.
Please post back if you need anymore help or advice.
Good luck.
Jun 26, 2010 | Dell Latitude C610 Notebook
Can't install xp in compaq laptop
you mean you need to downgrade your computer from Windows Vista to XP?
if so is the case, you need to go to the BIOS in the Boot menu, select IDE from ACPI.
put the boot option to boot from CD first or disable Boot from hard disk.
then you will be able to downgrade your computer from Vista to XP.
Jun 07, 2010 | Compaq Computers & Internet
Startup problem
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Dec 20, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Desktop is blank white
The problem can be solved by reinstalling windows vista.
Oct 24, 2008 | Microsoft Windows Vista Ultimate Edition
Black Screen
listen the answer is this. screen resolution set to a incorrect setting or video driver installed is not compatible with the hardware in the lappy. what you do is this when you reboot the lappy press the F8 key until it give alist of options boot to safe mode uninstall video driver by going to device manager or reset display resolution in the display setting try the latter first then reboot.
Apr 08, 2008 | Compaq Evo N610C Notebook
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Open Questions:
Need Help! Back Up And Restore Your Important Data On The Cloud Backup You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 23, 2018 | Best Computers & Internet
Do you REALLY Need A Cloud Backup Solution? The short Answer Is: Yes. Why Yes, You Do! Find out why: You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Cloud Backup For Small Business services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Server Cloud Backup Solution Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Backup Pricing Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
