Question about D-Link DSL-504T Router
Forgot password D-Link DSL-504 ADSL Router 4 Port or mack resetting
  • Jeffrey Groves
    Jeffrey Groves Dec 31, 2010
    Do you have physical access to the router?
    Novelist:
  • D-Link Expert
  • 199 Answers
Login into you router using your browser (connected by a LAN cable) and under the wireless section you should see the network password.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Posted on Jan 06, 2017
5 Suggested Answers
  • 556 Answers
SOURCE: D-Link dsl-2640b
see
http://www.smallbusinesscomputing.com/webmaster/article.php/2248681
The first answer seems to address your question however as noted in your article the mode you have is not on AOL's recommended however it does support PPPoE so it may (should?) work. I recommend setting it up and getting it to work with a computer wired to the router before configuring and testing wireless connections. In terms of wireless configuration see
http://www.fixya.com/support/t281214-wireless_security
Posted on Dec 06, 2007
OzKluger
  • 27 Answers
SOURCE: How to create a security enable router?
Firstly, confirm that your ISP connection for email and internet is working correctly. Then connect the router to the ISP using the ADSL plug, and to your computer using the ethernet connection. It is best to set up your router using a wired connection to your computer. Once set up, you can connect your computer using WiFi. Have your ISP username and password handy.
There are two steps to secure your router:
1. Change your ADMIN password. Using a web browser like Intenet Explorer, type in the address, http://10.1.1.1. This should take you to a sign-on screen. Username is "admin", and password is set at the factory as "admin". You should now be logged in to your router. Go to the TOOLS tab, and change your admin password. NOTE THIS DOWN FOR FUTURE REFERENCE.
2. Secure the wireless part of the network: Go to the HOME tab, and select either WEP security (good) or WPA security (better, but some devices like printers don't like this).
For WEP you will need to enter a 10-digit WEP key. Numerals will do, or you can use hexadecimal (base 16) notation if you know this. Numerals will do and are no less secure. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
For the WPA alternative, you should select the "Pre-shared Key" radio button, and code in your WPA password in the "PSK String" field. This can be a word and or numerals. I don't think spaces or other characters are allowed. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
That's IT!! You've changed the admin password and secured the wireless part of the network.
You will then need to code the WEP or WPA password into the devices like printers and computers that you want to connect to the WiFi. For Vista computers, right click on the network icon in the tray (two little computers overlapping) and select "Connect to a network". Enter the WEP or WPA password when you see SSID "default" or your SSID if you've changed it. Most printers have a connection wizard.
There is a further enhancement if you are really paranoid: change the SSID and turn off the SSID broadcast. Go to the manual at:
ftp://files.dlink.com.au/products/DSL-G604T-GenII/Manuals/DSL-G604T_GenII_Manual_v1.11.pdf
if you want further details. Good luck with your secure network.
Posted on Jan 19, 2009
niquose
  • 198 Answers
SOURCE: forgotten password for D-Link DSL G604T wireless router
These are the default settings:
When the login window appears, set the user name to Admin and leave the password box empty. If this doesn't work, you may also try admin for both username and password (all small letters).
If the default doesn't work, you may reset the password by pressing the reset button for 30 seconds. This will bring the router to factory default settings (including all the configurations set on the router).
Hope this helps.
Posted on Jun 25, 2009
SOURCE: Need latest firmware file for
It is responding... you are probably suffering the same issue as me. For some reason the MTU setting is causing issues with accessing the D-LINK website. The 2730B however does not allow you to change that setting anywhere (how ironic).
Your option is to use something like DrTCP (assuming you are using Windows) to change the setting on your local machine. Suggest changing to 1492 for the adapter you are using to connect to the Net (should make sense once you run the application).
This is what I did, and worked for me. Hope this helps you.
P.S. I'm about to throw the thing in the bin. It's got so many issues, the last D-Link product I ever buy.
Posted on Oct 11, 2010
How can I obtain a user guide for Acatel optus one touch 250 P/N16513 corded phone?
Optus Network Approved modem and equipment list
If you are supplying your own DSL modem and/or telephone filters, you must ensure they meet the requirements
below before connecting them to the OptusNet DSL network. Connection of unapproved equipment is prohibited.
The modem list contains equipment that has been certified by manufacturers as having passed interoperability tests
r
equired for use on a DSL network. If your modem make and model isn't listed below,
call Optus Customer Service for further information on
1300 309 333.
F
ully supported by OptusNet DSL Broadband Customer Service, the OptusNet DSL Broadband Installation CD-ROM will automatically
c
onfigure this modem.
D-Link ADSL Modem 302G
The OptusNet DSL Broadband Installation CD-ROM provides detailed information to manually configure these modems, and OptusNet
DSL Broadband Customer Service will provide limited connection support for them.
(Equipment Certification date in brackets)
F
or modems and routers other than those above, OptusNet DSL Broadband provides only the network connection settings needed for
manual configuration. While this equipment can be used on the OptusNet DSL Network, no OptusNet DSL Broadband Customer Service
will be provided for connection configuration or equipment-related connection difficulties.
Alcatel SpeedTouch - 510 ADSL Modem (15.01.2003)
Alcatel SpeedTouch - 530 ADSL Modem (15.01.2003)
Alcatel SpeedTouch Pro - 4 port (10.09.2001)
Alcatel SpeedTouch Pro - Firewall (09.10.2001)
Alcatel SpeedTouch PCNIC (04.08.2000)
Alcatel SpeedTouch USB (04.08.2000)
Askey/Dynalink - ALE 070 (08.01.2001)
Askey/Dynalink - ALH 110 (21.03.2001)
Askey - RTA100 ADSL Modem (25.10.2002)
Billion Electric - BIPAC-711 CE ADSL Modem (25.10.2002)
Cisco WIC - 1ADSL-DG (30.06.2003)
Cisco 827 (19.02.2001)
Cisco 827H (11.07.2002)
Cisco 827-4V (19.02.2001)
Cisco 837 (01.04.2003)
Cisco SOHO77 (29.11.2001)
Cisco SOHO77H (11.07.2002)
Cisco SOHO97 (01.04.2003)
D-Link ADSL Modem - DSL 100D (08.08.2001)
D-Link ADSL Modem - DSL 500 (08.08.2001)
D-Link ADSL Modem - DSL 504 (08.08.2001)
Efficient Networks - C10 Communications - Speedstream 3060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 4060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 5260 (08.01.2001)
Efficient Networks - Siemens - Speedstream 5400 (07.04.2003)
Efficient Networks - C10 Communications - Speedstream 5660 (21.03.2001)
Efficient Networks - C10 Communications - Speedstream 5667 (10.09.2001)
Efficient Networks - C10 Communications - Speedstream 5861 (21.03.2001)
Juni NetAce - ADSL USB Modem (15.01.2003)
Juni NetElite 2000ES - ADSL 4 port Modem (15.01.2003)
Juni/Samsung SAM-215 USB Modem (18.07.2001)
Juni/Samsung SAM-335A Ethernet Modem (18.07.2001)
NetComm ADSL Modem - BusinessSmart (08.08.2001)
NetComm ADSL Modem - USB - NB1200 (27.08.2002)
NetComm ADSL Router Modem - NB1300 (20.11.2002)
Open 501r ADSL Router Modem (05.04.2002)
Alcatel - Central, Part No. 3AU 04804 AAAA
Alcatel - In-Line, Part No. 3AU 04805 ABAA
Askey/Dynalink - In-Line, DT60-002BA
C10 Communications - Dynamic - In-Line, C10290
C10 Communications - In-Line, C10611 & C10611T
C10 Communications - In-Line, C10645 & C10645T
C10 Communications - In-Line, C10610
Te
l
ephone Equipment - Central, TE-ACP20AUS01
C10 Communications - In-Line, C10211
C10 Communications - In-Line, C10111
C10 Communications - In-Line, C10145
C10 Communications - In-Line, C10245
D-Link - Central, DSL-10SP
D-Link - Central, DSL-10CF
D-Link - In-Line, DSL-10MF
Alcatel SpeedTouch Home
D-Link ADSL Modem - DSL 200
D-Link ADSL Modem - DSL 300
D-Link ADSL Modem - DSL 300+
D-Link ADSL Modem - DSL 302G
Optus supplied modem
Optus preferred modems
List of all other certified modems/routers
List of certified filters/splitters
Information correct as at 2 February 2004.
1270049 06/04
Nov 12, 2014 | Cell Phones
D-Link DSL-2750U N300 ADSL Modem Wireless Router configuration with Hathway
YES THATS TRUE. TO CONFIGURE THE ROUTER. NEED THE PPPOE USERNAME AND PASSWORD FROM THE INTERNET SERVICE PROVIDER. VPI AND VCI SETTINGS.
..THEN ACCESS THE ROUTER PAGE
..GO TO ADVANCE SETUP PAGE.
..THEN LAYER2 INTERFACE
..CLICK ADD
..CONFIGURE THE SETTINGS.
..POWER CYCLE THE NETWORK.
Nov 21, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
Forgotten password and username to access router
If you forget the password, you need to reset the device to the factory default settings. In that case, all configuration settings of the device are lost then you need to reconfigure the router,
To reset the device to factory default settings, follow the instructions from this link,http://global.dlink.com.sg/site_support/DSL-2640B/Manual/DSL-2640B_manual_v2.pdf
11_20_2011_12_11_30_am.pngHope this helps.
Nov 07, 2011 | D-Link - DSL-2640B Wireless Broadband...
How can I find device owner password on my Wifi ADSL Router SMC Barricade g?
Hello, the default username AND password for most routers is 'admin' all in (lowercase) and without
the ' '
regards,
Nicam49
Oct 23, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Problem with my adsl 2+ router glb-502t
check if you have the correct username and password for the ADSL line entered into the router, if its correctly entered then reset the router once it should ideally pich up the ADSL Connection.
Mar 28, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
Lost user name and password for configuration manager
If you forgot your password, you must reset your modem.
Note: This process will change all your settings back to the factory defaults.
To reset the modem:
Step 1 Locate the Reset button on the rear panel of the unit.
Step 2 With the modem powered on, use a paperclip to hold the button down for 10 seconds.
Step 3 Release the button and the modem will go through its reboot process.
Step 4 Wait about 30 seconds to access the modem.
After restart the modem you can use default username and password (admin/admin)
For further help you can check the link below
ftp://ftp.dlink.com/Broadband/dsl2640B/Manual/dsl2640B_Manual_100.zip
Mar 22, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Adsl2+
don't go for the cd you configure your self abd it think that your dsl not get the perfect dsl link
Jul 10, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Unable to install after 81 %
If the setup CD is unable to setup your modem/router (it is also called a "gateway") you can do the router configuration via the Web User Interface of the router. you will need ADSL settings such as:
a. Encapsulation mode. (typically PPPoA or PPPoE)
b. Multiplexing: (it can be LLC or VC)
c. Virtual Circuit Range.
d. Username & Password (ADSL UN/PW)
note: All of these ADSL settings should be provided/given to you by your ISP/ADSL provider. You can call your ISP for this settings.
just notify me if you will need further assistance doing this, but first make sure you have all the settings for ADSL.
Apr 18, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Finding the user name
You must use the RS-232 serial cable using terminal emulation software such as Microsoft HyperTerminal. Connect the cable from your computer to the console port on the DSL-500 or DSL-504. Step 1: Go to Start>Programs>Accessories>Communications>Hyperterminal. Step 2: Enter a name for your connection and choose the default icon selected. Step 3: Select a COM port (usually 1 or 2) and click OK. Step 4: The terminal parameters will need to be set to as follows: Step 5: At the command prompt type isfs cat inituser and press enter. You will now see the username and password.
Feb 16, 2006 | D-Link DSL 500 (DSL-500) Router
D-Link DSL-504T Router Logo
73 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
