Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
Tv makes a noise when turned on cold other wise works fine
    Top Expert:
  • Sony Master
  • 74,118 Answers
Hello
Your TVs anode cap is arcing. The sound you hear will be like "Ishhh", and a fouling smell of Ozone also be there from the top back side of your TV.. It will stop after some time, say after 10 or 15 minutes; and picutre will be oke thereafter. You must get it repaired without any delay, otherwise the final anode will get rusted, and will turn the picture tube irreparable.
The final anode of the picture tube is clipped into and is protected by a rubber ******, called anode cap. When the the humidity in atomosphere increses, the arcing also will incresae, and will take much time to get picture to come clear. Anode cap is a replaceable part, even though it is integreated with Line Output Transformer. Proper care must be taken when replacing it, and must be done by a well experienced technician. Do it atonce as fast as you can, otherwise thigs will go worse. The anode voltage of a 32" tv comes upe to 28,000VDC [28KVDC], so it is dangerous to handle by yoursef, if you are not experienced. The charge at that point will hold over for hours, even after the set is switched off. Anode must be well discharged before handling the anode cap. A well experienced on only can do this. Do it without any delay I advice you. OK.
Posted on Jan 02, 2011
Why it doesnt start and make a long noise
Grandson just had this problem with our dryer. he was setting the timer by turning it counter clock wise, all he got was a buzz. When it set it clock wise it worked find.
I know this is a simple fit but worked or him
Randy
Apr 29, 2014 | Siemens WFXD5200UC Front Load Washer
Truck makes noise when turning for the first time when cold
use an electronic stethoscope to find it , or 2 persons.
no body here can find noise, ,impossible.
Feb 02, 2014 | Toyota Tacoma Cars & Trucks
Having trouble getting oil cap of engine.
THis can be a little hairy, but use a big screwdriver or a cold chisel and use a hammer to tap the screwdriver on the right side of the cap, turning it counter clockwise. Let me know if it helped. Oh, and then be sure to lube the mounting area when you put it back on.
May 03, 2012 | 1997 Jeep Grand Cherokee
Tv works then whirring noise like a motor stops and starts again
Bad Color Wheel Call Encompass for Part 1-800-638-3328 DO NOT KEEP playing TV untill this is Fixed other wise you can cause Alot of Damage to Set.
Sep 26, 2009 | Thomson 35776650 Bulb for 44DLP540 Rear...
My tv turns off right after you turn it on?
simple un-plug the tv for about 30 secs. that should reset the memory on the tv. i had that problem and that is what i did and it worked however if it does not then you need to clean the button other wise send it for a repair or buy a new one
Feb 16, 2009 | Emerson EWF2004 20" TV
CRT TV Screen Colors Off
The tv needs degaussing (demagnetizing) unplugg the set tonight and then plug it and turn it on in the morning. You should hear a a "bonk" noise when the set is first turned on after being cold- this is the internal degausse circuit working and it should fix your problem if you don't hear the "bonk" sound or it does not fix your problem call arepair shop to have the degausse your set and possibly fix the internal degausse circuit.
Dec 23, 2008 | Panasonic CT-32HX42 32" TV
My Carrier 58dxc is making a loud noise
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Dec 02, 2008 | Heating & Cooling
Whirring noise in clothes dryer
check rear tub rollers and also check the idler pulley
May 11, 2008 | Dryers
Samsung TX-P3271H Noise on cold start
greetings from belize that noise is normal it is just the boost up voltage that the set is hauling to operate.nothing to worry about.good luck.
Dec 21, 2006 | Samsung DynaFlat TX-P3071WH 30" TV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
