Question about Sony KDF-E60A20 60 in. LCD HDTV
Lamp light is on. TV won't work. - Sony KDF-E60A20 60 in. LCD HDTV
  • 269 Answers
I would replace the tcon board. usually dead center up top covered by a square metal cap. First reseat the connectors going to it and the multi colored wire cable at the Power supply board going tto the T-Con board.
Posted on Dec 31, 2010
My Sanyo tv is not working. The power light comes on and then starts blinking red.
I myself had a 55 inch hdtv ready projection tv and the lamp went out in it. It cost me $104.00 plus shipping to replace it. Check out discount replacement parts but remember that if it is a projection tv, it won't last but approximately two years and you will have to do it again.
Aug 25, 2012 | Sanyo SELECT PLC-XP45 Rear Projection...
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Samsung hln617w won't turn on fans run lamp and temp light go on
2 different brands and models listed here--for the Samsung inspect to see if color wheel is intact and not shattered---have to remove the lamp to see it.
Apr 29, 2012 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Replaced lamp, tv worked great for a week, yellow blinking status light, dust cover is secure and the switch is good. tv won't power up
Now the tv projection lamp tries to light up to the tv screen and shutting itself down,u hearing tv make alots of cliking noises to the tv set too?Yes,mean the Ballast board it is also dead,now must replaced the Ballast board too.The Ballast board only job are to ignite the tv projection lamp only.
Aug 09, 2011 | Mitsubishi WD62527 62 in. LCD HDTV
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
