The does not spin when put few clothes - Washing Machines
  • Washing Mach... Master
  • 8,220 Answers
Some do not wash with a small amount of clothes. It is recommended to add more clothes. The idea is saving water and energy by not washing one thing at a time.
Some various errors for front load washers:
IE: Water level (246) was not reahed in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Posted on Dec 31, 2010
Finding balance for spinning
You must put your clothes in evenly...and don't over full with clothes
Apr 06, 2013 | Frigidaire Washing Machines
Washer won't shift into spin
with a lot of the machines now they wont go into spin mode if the drum is not balanced properly, like say you had a load of towels in their, well it wont spin as its to unstable to spin without wobbling around so it simply stops at the spin cycle and does nothing, you can try this by turning it on with no clothes in and see if it will go into the spin cycle with no clothes in, if it does then chances are its not weighing the clothes properly and would end up costing a fortune to put right as it sounds like you spent a lot of money on parts all ready, so give i a try with no clothes in and see if it will spin, have you tried turning the drum by hand when its switched off to check for any grinding noises or jerking when you try to turn it by hand, im not sure how the balance sensor works or even where it is as its a new feature in the last few years but people are now starting to have problems with this feature and it stops the machine from spinning leaving the clothes soaking yet, so give it a try empty and see what happens
May 16, 2012 | Whirlpool Washing Machines
My whirlpool model LSQ9549PWO won't spin
have the motor checked out as it could have winding problems or start/run capacitor problems
Apr 05, 2017 | Washing Machines
No problem just want to know if one can put clothes soaking in bucket into the machine and go straight to spin to get excess water out without going thru the whole washing process. Cheerz!
Hi - yes theres a few options start it on the final rinse and set your water level to low or auto sense then spin speed (this will add more water to stabilesde the spin cycle)
Could go direct to spin as well but you will need to adjust the clothing proper prior to starting of the cycle..
Jul 10, 2011 | Fisher and Paykel GWL11 Top Load Washer
I got a ue code
UE means unbalance error. It means the machine can't balance the clothes in the drum so it won't spin to prevent excessive vibration and damage to the machine.
Usually opening the door and rearranging the clothes helps, or take some out then put onto a rinse and spin. If there is just a few items in then it will struggle to spread them around and balance.
Mar 02, 2011 | LG Washing Machines
Washing machine low spin rpm's
If the electric motor has carbon brushes, check they are not worn out.
Jul 02, 2017 | Whirlpool Washing Machines
My washer will spin but not with clothes in it?
Ckeck to see that the lid-switch activates when you put the lid down ,maybe the probe on the lid is broken off and then there won't be anything to push the switch down to make it spin .
Dec 28, 2008 | Whirlpool LXR6432JQ Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
