Question about Olympus FE-230 Digital Camera
I am trying to upload pictures from my camera. When I plug it in and select to upload to my pc, the camera says "one moment" then does nothing from that point.
  • 639 Answers
Maybe your PC still don't recognize your camera. Have you installed the driver properly ? Sometimes a driver need an internet connection to be activated. Or there is OS problem, like if you installed x32-Windows based driver in x64-Windows based PC, or the opposite.
I think you need to reinstall your driver, if the problem persist just take off the memory card and use a card reader to open it.
Hope this help. (^_^)
Posted on Dec 31, 2010
Computer doesn't recongnize sony camera usb
To download the pictures you need the driver for the camera ...this can be downloaded from the support site if you do not have it ..but from what you said it seam that the issue may be of other cause..
The camera need to be powered and on ..in the moment you connect it to the computer ..and also you need to confirm the pc connection from the camera in the moment you connect ti .make sure you have its driver installed .
Try to connect in a different usb port ..cause even if the driver is missing the computer should react on the usb device being plugged and ask for the driver.
If no port will react ..try the camera oin another computer ..and like I said always make sure it is powered and on ... If it makes no reaction in another computer ..than something is wrong with the camera .Another method to download the pictures..is to use the card from the camera directly into a card reader and copy the pictures from it ..
here is a link for the driver if you need it ..
http://esupport.sony.com/US/perl/model-home.pl?mdl=DSCW370G&template_id=1&region_id=1&tab=download#/downloadTab
this is teh picture browser it uses...be sure you select the operation system you run ..and also make sure you download the full program first and the upgrade after ..cause the update download may not work without the original one ..(down on the list ) ..
Good luck !
Nov 25, 2011 | HP Pavilion dv9000z Notebook
I lot CD for my 1-2mp Samsung digital camera to upload on pc. how to upload this now
no cd required.
plug the camera to the computer and turn on, if camera asks select PC.
on computer open My computer or computer folder and then find the removable storage device which is the camera, inside you will see DCIM folder and then your pictures you are free to copy, print, email, etc these pictures from there to your computer etc.
Jan 17, 2011 | Samsung Cameras
I've had my E-300 for 3-4 years now with never a problem, until this.... . Recently, whenever I try to upload photos onto my PC I click "Ok" for the "Storage" function, the red light...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 29, 2010 | Olympus EVOLT E-300 Digital Camera
Sony camera says Switch on [MENU] when i upload pic from USB cord
1) Try uninstalling then re-installing your Sony software.
2) When you connect to the PC and switch on, Click on Start - "My Computer". Your hard drives and disk drives should appear in the window.
Have a good look, is there a new drive, it may be called Sony, or USB mass storage device it may just be called drive E or F.
If so double click on that drive, if there's a folder there, double click on there, with luck you should see your pictures, that new drive is really your camera.
You should be able to move pictures by copy and pasting. Once copied you can deleted them from your camera.
3) You can buy a device called a "Memory card reader" Make sure its good for sony memory sticks.
You take you card from you camera and put it in the card reader. Then, once plugged into a USB port its just like another HDD as described in 2.
4) I should have said this first, try another USB port if you can, it my just be dust in the port making life hard............
Good Luck.
May 08, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Pictures not uploading to computer
Take the memory card out and see if you can load it into another computer using a card reader and see if the memory card is good.
It could be a bad cable but at least if you can copy the card to the hard drive have your pictures.
Jul 06, 2008 | Olympus Stylus 700 / 700 Digital Camera
Upload pictures to the hp photosmart 435 digital camera
You can do it through Windows Explorer.
Plug in your camera via USB cable to PC. Make sure it gets detected. Right click on the START button and select Explore. In the left hand pane, if you scroll down, you will see your camera listed as a drive (usually after the DVD/CDROM drive). Click the (+) next to the entry to expand the folders. (Copy the images you want to import into the camera from the PC location first). Now simply locate the folder in your camera drive that stores pictures, right click and paste them.
Please take a moment to assign a Fixya rating if you found this solution helpful.
Jun 02, 2008 | HP Photosmart 435 Digital Camera
Won't connect to computer
Try setting your camera to preview option and plug it in then look under my computer for a extra drive letter.
Apr 02, 2008 | Olympus FE-230 Digital Camera
Won't upload pics to PC via USB
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 15, 2007 | Olympus Camedia C-770 Digital Camera
Uploading pictures to my computer
Hi , in uploading picture let camera on ,plug usb , detection come in screen message , et camera button ignore it / click set camera ,select upload to camera, selection of pictures then okey.
Nov 02, 2007 | Fuji FinePix S3000 Digital Camera
Olympus FE-230 Digital Camera Logo
168 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
