Question about Moen 24 In. Towel Bar...
The towel bar keeps coming off the brackets. How do I get this corrected?
    Problem Solver:
  • 5 Answers
Hi. Are the brackets (mounting posts) the correct distance apart? For a 24" rail, they should be 26.22" apart (outside to outside). If they are not then they probably need to be moved so that they are.
If they are correctly spaced, are the "notches" in the mounting posts facing downwards? If not, make this so.
If the notches are facing downwards, are the screws tight enough? If, not, tighten screws.
Hope this helps. Regards, Myles
Posted on Jan 01, 2011
Towel rack fix came out from wall
Go to a hardware store and wall anchor screws to reinstall the brackets that hold to towel bar to the wall. There should be two brackets and two holes on each bracket. If the existing holes are to big, drill two new holes on each side. Screw the brackets to the wall. As you turn the screw, the will expand in the screw hole and hold the brackets that you attach the towel bar to.
Feb 02, 2018 | Towel Rack Home
My towel bar won't stay tight
maybe you need new screws in the bar?
Nov 30, 2012 | Delta & Soap Dispenser
How do I install a moen mason towel bar?
Do the tips come off? Is it possible that the bar slides through the brackets? Most high end hardware has very small Allen screws to mount it. If not, go to Moen website for instructions or a phone number
Mar 24, 2012 | Moen 24 In. Towel Bar...
I have removed the piece requiring the hex tool. However, I can't get the base off the wall. How can I remove it?
The base is probably connected to wall with toggle bolts, thus meaning , as you try to unscrew the bolts that keep spinning, pull on the bracket away from wall as you unscrew the bolts and it will come off.
Aug 31, 2011 | Moen 24 In. Towel Bar...
I bought towel bars at a yard sale and the wall brackets are missing. Is there any place I can buy the mounting wall brackets?
Yes, Bed bath and Beyond, they have the parts as well as lowels and home depot. Let me know if this helped by posting 4 thumbs. Thanks mike
Jun 12, 2011 | Gatco & Channel& Satin Nickel Towel Bar
I have a franklin towel bar and the mounting bracket broke at the screw hole. is there replacement mounting brackets avaible?
Probably not, but if they sell a toilet paper holder of the same style the bracket might be identical to the towel holder, but would be cheaper than buying a new towel bar. Good luck, Al K
Mar 16, 2011 | Franklin BATH UNLIMITED NORTHPORT TOWEL...
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Moen 24 In. Towel Bar... Logo
1,322 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
