Question about DeLonghi MW 535 Microwave Oven
Mica -sparking and on fire
Hi my micro wave went on fire and my husband pulled this part out as this was the problem-but i dont no what to do now -can i use it? when can i get it replaced? or can i cut of the burnt bit?
  • DeLonghi Master
  • 9,086 Answers
If your waveguide cover is burned, it will need to be replaced.
You can order spares here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 08, 2008
Hole burned in panel inside next to ligt
take it in for repairs or just replace it
Apr 26, 2015 | Sharp Microwave Ovens
Sparks from wave guide
the magnetron may have burnt itself up. it may be time to replace
Nov 05, 2013 | Microwave Ovens
Replacement mica cover for sanyo d95535n microwave
Hi there micro
There are things that the microwave does not like. One of them is aluminium or metal for that matter.
You can buy plastic hoods or just cover the plate with plastic film not forgetting to pierce the film in several places in order to let the steam escape.
all the best
Kolbrun
Apr 09, 2012 | Sanyo Microwave Ovens
My emerson microwave #mw8999rd shoots out fire from a silver piece of cardboard thats on the righthand inside of my microwave oven. whats with that?
There is electrical problem in your microwave heating circuit. This is a fire hazard and you should stop using this microwave and unplug from the outlet. This is not something you can fix and the fuse does not protect your system anymore. The best choice is to purchase a new one and throw this away.
Dec 06, 2011 | Emerson Microwave Ovens
My Galaxy over-the-range micro #80009401 has a 4"
That sheet is called the Wave Guide Cover and must be replaced. It is made of Mica and protectes the magnetron and aerial.
Feb 03, 2011 | Kenmore Microwave Ovens
Jenn air micr-/convectionoven arcing while running
There are 3 possible openings that you could be alluding to. One is for the light, one is for the air vent, the 3rd is for the magnatron micro beam energy. The sparking can be from dirt buildup, from a loose connection, from a fan blade rotating or from the scatter blade rotating, or from the magnatron gun shorting, or from the mica cover plate if so equiped. Best to carry it in to a service place; it is usually worth fixing, adn only the magnatron failure would be the highest cost of the repairs. it is at least worth spending a diagnosis cost for someone to tell you the real reason and you'll know for sure if you made the right decision. Goodluck, Macgivor
Jan 02, 2010 | Jenn-Air JMV8208AAS Microwave Oven
Sparking roof of my miele M613G microwave
these ovens are favourite for this, it is something to do with the stirrer blades. the top casing can be removed and replaced
Feb 23, 2009 | Miele M613GSS 800 Watts Convection /...
I have a sharp micro wave oven. Occasionally, when some foods are cooked or heated, you can see small bursts of blue flame. What I should do ? I only use microwave safe containers.
You probably have a burnt wave guide cover. Look inside the microwave either on the side or on the top, it's a square piece of mica board, and you should see a burnt spot on it. You should be able to replace it fairly easy with the model number I can check on a replacement for you.
Jul 09, 2008 | Sharp R-220HW Microwave Oven
Popping and shooting sparks
Hi There!
Check behind the "Wave Guide Cover" on the inside cavity. There may be moisture or food residue behind it. Should be a cover that is plastic or Mica. Really strange that it's sparking being new. Also check that you use plates without gold or silver trimmings (Crockery or porcelein). This will also cause sparking. Remember that microwaves will always go to the first organic source in its path. The wave guide cover, if soiled, is very close to the tip of the Magnetron and will therefor result in arcing. Good Luck, JUS004
Feb 26, 2008 | Frigidaire PLMV169DC Microwave Oven
DeLonghi MW 535 Microwave Oven Logo
153 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
