Question about Samsung HC-R4755W 47" HDTV
I'm trying to use my HC-R4755W as a display for my computer but cannot get the entire desktop onscreen. I've fiddled with every control on the TV and display properties on the computer, but the edges are all clipped. Any advice would be appreciated.
  • 11,896 Answers
You can resize the screen.
You can also change the screen resolution size or the box sizes on the screen.
Posted on Dec 31, 2010
Our Samsung tv will not turn on/power on. It sounds like it starts to power on, the light blinks twice then you hear something, the light stays on solid after that. This model usually has an audible tone...
I would suggest two things you need to examine :
First remove and examine the lamp to make sure it is not shattered or fractured.
Second examine the color wheel that faces the lamp (see attached photo) and if you had a fan like sound or high pitched whine before that points to the color wheel.
The color wheel is a do it your self replacement (I can help) and takes less than a hour.
Let me know what you have tried and if the lamp or color wheel are intact.
SD TECH
Sep 16, 2011 | Samsung HC-R4755W 47" HDTV
How do i connect computer to tv
you need a tv out pci card for you computer which you can buy from your local dealer
when you buy it make sure you get either a hdmi cable or jacks
hope this helps
John
Jun 12, 2011 | Samsung HC-R4755W 47" HDTV
My Akai pt5499HD has no picture to it and i just replaced the flyback transformer to see if that was the problem. any suggestions?
You need to have copy of service manual for this tv and Samsung PT5499HD service manual will work on your Akai tv as both has same circuit.
Aug 26, 2010 | Samsung HC-R4755W 47" HDTV
THE RED ON /OFF BUTTON FLASHES BUT NO SOUND NO TV
check the speakers conection or the volume remote
Nov 09, 2009 | Samsung HC-R4755W 47" HDTV
Onlytwo lights are lit and screen is blury
Adjust your screen/focus control you have r/g/b for each tube they are located on a small black control box R/G/B screen drive control on botttom and focus is on top.
Jun 17, 2009 | Samsung HC-R4755W 47" HDTV
Samsung HC-R4755W turns on and off by itself.
Have Capacitors checked in the power relay circuit, also if you have young children who like to push the buttons on the front of the set make sure none of the buttons are sticking inward or stuck in a pushed in posistion. More then likely it might be caused by a faulty System control board which we call the signal board, or bad connections on the power supply, Have a tech check the connections on the Flyback transformer and the High Voltage Deflection Area on the HV Power supply. I believe you have Cold Solder Joints in the HV Power Supply.
Hope you this helps you..
Apr 21, 2009 | Samsung HC-R4755W 47" HDTV
Have you found a soultion?
I gave up. Repairman said it would cost $500 to fix.
I'm going to be buy a new TV instead.
Mar 30, 2008 | Samsung HC-R4755W 47" HDTV
TV won't turn on or stay on?
no solution, Did Samsung get me for 999.00 plus tax?
Flickering Screen
soon the picture going to go to black screen, you got somes capacitors bothering, you better to call a tech now that he can see the problem, later will cost you more..good luck ps the picture many times tell to the tech whats going on.
Aug 07, 2006 | Samsung HC-R4755W 47" HDTV
Samsung HC-R4755W 47" HDTV Logo
90 people viewed this question
Jerry Greenberg
Jerry Greenberg
