Question about Breville BBL600XL. 5-Speed Blender
I think I overloaded the blender. Seems like it over heated. now the light on controls goes on but blender does not run when I push buttons. I checked the fuse and its good. What else should I check?
  • 11,896 Answers
If fuse is good and light is on, then you are getting power. Most likely and very very commonly the motor is fried. I have done it myself with 3 of these things.
Posted on Dec 31, 2010
KitchenAid Blender
The motor will probably be open circuit, take it back under guarantee and let them sort it out. If you mess around you will void your guarantee.
Aug 05, 2014 | KitchenAid Blenders
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Mar 21, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blender has lost top two speeds
With my blender, some of the buttons stopped working, and I found a simple way that fixed it like new, with no special skills or replacement of parts. To determine if this fix will work for you, unplug the blender and press on each button. As you do this feel and listen for a definite 'click'. If you here it for the buttons that are working, and not for those that aren't, you probably have the same problem.
I discovered that there is a tiny mechanical push button switch under each button. The switches are held snug to the bottom of each button by a thin metal bracket. If you have heavy fingers, the force of pressing the buttons over time, causes the bracket to deform, moving the switches further and further away from the buttons until, eventually, no matter how hard you press, they are no longer close enough to depress the switches underneath.
The solution is to simply open the blender (with the power cord removed) and gently push the button assembly back towards the buttons. To get inside you need to pull out each of the four rubber feet, and unscrew the phillips head screws that are hidden under them. Next, seperate the top and bottom sections by gently pulling the power cord through the strain-relief (don't worry, it goes back together very easily). Before putting it back together, check the buttons (always with the power cored unplugged !!!) for the 'click'. If this doesn't work, you may have to take out the two screws that fasten the bracket to the blender, and bend the bracket hold-down tabs with a plier, in the opposite direction of the switches (that way when you put the screws back in, they'll move towards the buttons. That's it.
Hope this helps someone like me save about $150.00 for a new one and keep another 10lbs. of junk out of the landfill.
Nov 08, 2008 | KitchenAid KSB5 Ultra Power Work Top...
Black and Decker BL3900 stopped working
I had the same problem with BL6000 model. After using the blender few times it went dead, though on occasions it ran for a couple of seconds or so. I opened the base and saw the red light come on and off in response to pressing the buttons, but the blender would not run. I checked the connections and resistances across various points, and then decided to bypass the digital control panel by joining the blue (AC) and black (motor) wire terminals, as the control panel must be altering the frequency or voltage going across this connection into the field coils (and also to rotor). The motor is rated at 120V. The motor ran perfectly, though i let it run only briefly, confirming that it itself is all right. I think one must check a step further by studying the current and voltage characteristics to ensure that the motor does not consume more than rated 550 watts if you do not wish to buy the digital control panel ( part number BL5000-01-01, available through partstore.com or black and decker partner site. It should fit BL6000 as per partstore.com). The motor seems like an univeral motor. If anyone knows more about motors and has the same problem, then pl let me know if bypassing the digital control panel and using an external switch to shut the motor on and off is a good idea (digital panel and shipping will buy an equivalent blender in stores, about $18). I am afraid that if digital control panel does not let unregulated power be delivered to the field (and rotor) coils, then one may be putting too much power into the motor and it may burn out prematurely.
Oct 15, 2008 | Black & Decker BL5000 ProBlend Work Top...
Kitchen Aid blender
to see if its the Triac or just the off button perform this: connect the blender,while pressing the off button press the on button; if the blender stays on and you dont hear the relay function (Light ticky sound) maybe the off button get a broken solder point. But if the relay is functioning and there is no way to change the speed the problen is the TRIAC. This is a small piece on PCB with a heat sink
Aug 30, 2008 | KitchenAid KSB3 Classic Work Top Blender
Blender blinks
need to resolder the triac located on the Printed circuit board this part is on an aluminum heat sink, and the third leg is most of the times the one with a broken or poor soldering joint due to the vibration of blender
Dec 27, 2007 | KitchenAid KSB5 Professional Stainless...
Blender won't work
This indicates an internal problem with the blender itself as pertaining to the motor. I would suggest contacting Kitchenaid Customer Service to see about having the blender repaired or possibly replaced.
Their toll-free phone number is 1-800-541-6390.
Also, a listing of Kitchenaid certified repair facilities may be found at the following link:
http://caservice.kitchenaid.com/
Sep 06, 2007 | KitchenAid KSB5CR Chrome 5 Speed Blender
Breville BBL600XL. 5-Speed Blender Logo
764 people viewed this question
Top Breville Blenders Experts
Mike
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
