Question about EA - Electronic Arts Dark Omen / Syndicate Wars for Windows
I have a no CD patch, it modifies the engrel.exe file but still asks me for a CD when I try to run the campaign. Anyone know why?
How do i run medieval lords on windows 7 ? please help im dying to play some classics
Here is how I managed to get it to work on Windows 7.
Download the patch at www.gspsupport.co.UK/media/patches/Medieval_Lords.exe
1. Save the file Medieval_Lords.exe to your desktop
2. Right click on the Medieval_Lords.exe on your desktop and left click 'Cut'
3. Go to C:\Program Files\Monte Cristo\Medieval Lords\BIN
4. Right click in this folder and left click 'Paste', this will ask you to replace the Medieval_Lords.exe , click 'Yes' .
5. Go to C:\Program Files\Monte Cristo\BIN\DATA\SHADER
6. Rename the file named StdMatDX8.fx.bin from "StdMatDX8.fx.bin" to "StdMatDX8.fx"
7. Run program as administrator
Hope this helps
Jan 18, 2011 | Monte Cristo Medieval Lords for Windows
How do you active a patch for a game once you download it? It is an unofficial patch
This depends on the game and who made the patch.
MOST patches have what is called a self extracting installation file.
Assuming this is a windows machine.
It should have an .EXE extension. Double clicking this will cause the file to execute and install. Be careful however. Unofficial patch Screams VIRUS!!! Also keep in mind running patches will cause anyone with a different version number to be unable to connect with you in a multi-player game.
Use caution and certain of who and where this patch came from.
Oct 03, 2009 | Jade Empire Special Edition for PC
Why does it ask for the cd when it's already in the drive, the CD for Drakan: Order of the Flame?
you need to crack the exe file of the game to play it without the CD. the crack file is inside the CD, find it and copy it over the game directory.
Oct 01, 2009 | Activision Drakan: Order of the Flame for...
Upgrade for settlers downloads but won't run
I had this issue as well. Download the patch directly from the website, and run it locally. Afterwards the updater won't find a newer patch, and goes directly to the game. I don't know whether this will break again once a new patch is released, but you should be able to manually install it again at that time. Patches can be found at http://www.ubi.com/US/default.aspx under support --> patches.
This link may take you directly to the right place.
http://www.ubi.com/US/Games/Info.aspx?pId=5923&tab=download&dcId=63
Aug 02, 2009 | Ubi Soft Entertainment The Settlers: Rise...
I just installed Easy-Mark on a vista computer. There were no problems during the install, but the program stops working when I try to open it.Is there a patch I can use to get this working on my machine?...
You can try to modify the following properties of the executable file, EasyMark.exe.
1. Use Compatibility Mode as "Windows XP SP2" to execute this program.
2. Under "Advance Properties", select the option to run this program as System Administrator.
Jul 08, 2009 | Panduit Easy-Mark Labeling Software...
Where to get games for r4 cards
ok look up roms for the games but i dont how to work ds games which most people ask for. i have heard of a way to hack the capabilites of the ds with two cards one the PASSME card which is the ds carttridge and then the micro sd card slot that is the GBA slot on the bottom.
Super Nintendo games and any games before need emulators.. and the emulators need to be patched before they play.
google up super nintendo roms or the the title of a game and then rom.. Mega Man X3 rom
patching
ok here we go!!!!!!rusty on this!!! so ur card is working but games no.. well if ur emulators are not pacthed they wont start so patching the emulators [or programs like ultra thing] will make sure its runs on ur R4 and make sure you download files for R4. here are the files and sites
http://hbnds.biohazardteam.org/ has emulators!! they let you play snes nes and more
http://chishm.drunkencoders.com/DLDI/#patchers ok go to the R4 files for this site ok and also it has the patching programs on the bottom Win32
extract the file ok get the dlltool32.exe file and drop it in a folder on your desktop and put the file for your R4 in the folder to and the emulator also then run program dlltool32.exe and chose the patch file you downloaded and the emulator file and run it! it should say patch success and now set the emulator and any files it came with and add games in the card and run it should work
Jul 02, 2009 | Nintendo DS Lite Console
On gta chinatown wars it says save data cannot be acsesed please turn he ds off and reinsert the ds card
patch GTA using dslazy.
Small gui to some NDS utilities.
- get nds file info using ndstool.exe
- append a file to ndsloader.bin
- apply ndspatcher.exe to a nds
- grep for bricker code in .nds
- trim blank space out of a rom
- unpack and repack a nds using ndstool
extract to somewhere eg C:/ds/dslazy
run dslazy.exe
select a nds file(which is GTA right?) by hitting the "..." button.
get the rom info by clicking the [?]
hit the desired patch button
select where you want the new file to be if appropriate..
Unpack the said nds file(GTA)
search ARM7 download on Google, and DL it
then paste it on the unpack nds files which is on your ds lazy folder "NDS_UNPACK folder" overwrite if ask. Then repack it save the repack nds file wherever you want and your done copy the patch GTA on your SD card. If you don't get it try searching ARM7 patching on google.
Jun 12, 2009 | Nintendo DS Lite Console
Windows logon.exe error in XP
try thease steps 1. Insert a XP CD (any XP install CD will do for this procedure) and boot up.
2. When asked, boot to the CD by hitting the Enter key.
3. After a short while, a menu will appear.
Select R for repair.
4. Next, you will be asked which Windowsmag-glass_10x10.gif installation to use. Hit the 1 key on your keyboard and then Enter (assuming it is the C drive).
5. You may be asked for an administrator password. At which point you will need to enter it or hit Enter if their is none.
At the resulting C:\Windows> prompt in the recovery console , type 'CD System32' (without the quotes).
6. Next type:
'copy userinit.exe wsaupdater.exe'.
7. Exit and reboot normally. You should now be able to logon. But you're not done yet!
8. Run regedit from the Run line.
9. Find the Userinit key in:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\
10. Modify the entry:
C:\WINDOWS\System32\wsaupdater.exe
so that it reads:
C:\WINDOWS\System32\userinit.exe
May 20, 2009 | Computers & Internet
Scrapland and vista, error starting game - solution?
my friend you can go to launcher.exe and
1 right click and properties .
2 compatibility and then select mode windows XP/nt
click on the other icons try it works.
reply about the result.
Mar 28, 2009 | Enlight Interactive Scrapland for Windows
DS R4
ok well if you want to play emulators you need to patch the files!
http://chishm.drunkencoders.com/DLDI/#patchers has the r4 file and the patcher called win32.
run the dlltool32.exe file and add the patch file and the emulaotr then patch it add it to ur dss card and it should run! DS games may need a emulator
Feb 14, 2009 | Nintendo DS Console
EA - Electronic Arts Dark Omen / Syndicate Wars for Windows Logo
43 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
